Some errors in running deepstream-app
**• Hardware Platform (Jetson / GPU)**RTX3080
• DeepStream Version6.4
When disabled [sink0], I have error as
Warning: 'input-dims' parameter has been deprecated. Use 'infer-dims' instead.
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
GPUassert: invalid device ordinal src/modules/NvMultiObjectTracker/context.cpp 61
If I set it enable=1, I have no issue.
Then when stop app using ‘q’ or ctrl c, I have the following error
malloc(): unaligned tcache chunk detected
Aborted (core dumped)
from
gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_NULL); inside
function destroy_pipeline (AppCtx * appCtx)
in deepstream_app.c file.
What is wrong?
could you share the configuration files you modified? let me have a try.
iFocus_main.txt (6.1 KB)
Thank you
Thanks for the sharing! no sink is unreasonable. please enable one sink.
So one sink with fake one. Then how about error at stopping program using key q or control c
I am unable to reproduce that crash issue. here is the log. log-3.26.txt (2.7 KB). could you use gdb to get the crash stack?
gdb —args ./deepstream-app -c …/…/config file?
Used the command
When key in ‘q’ to stop program, I have the following outputs.
Thread 0x7fffe11fd000 (LWP 5256) exited]
[Thread 0x7fffe09fc000 (LWP 5257) exited]
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
[Thread 0x7fff41fff000 (LWP 5269) exited]
[Thread 0x7fff58ff9000 (LWP 5268) exited]
Thread 1 “deepstream-app” received signal SIGABRT, Aborted.
__pthread_kill_implementation (no_tid=0, signo=6, threadid=140737034633216) at ./nptl/pthread_kill.c:44
44 ./nptl/pthread_kill.c: No such file or directory.
The error is happening at
  1. did you modify the code? could you continue to narrow down this crash issue? destroy_pipeline and deepstream-app code are opensource.
  2. did you test in docker container? if not, Please provide complete information as applicable to your setup.
• TensorRT Version
Ok sure I’ll look into it. I changed a bit on deepstream-app. It should b from my modified part. Thanks
