I don’t know if anyone here has a clue about it or had a similar issue in the past but i’m having some problems with Shadow of Mordor , Hitman , LiS , Dirt Rally. However other Feral ports like Medieval 2 and Shogun are working ok yet Shogun shows gpu as " unknown " at in game settings page.
Problem is described here , any Nvidia devs had a clue to locating problem or any user has knowledge about it?
opened 10:33AM - 22 Oct 17 UTC
My problem is a bit different from issue #3 i guess.
You suggested me Xpander… 's solution, however it didn't worked. I've put that to Dirt Rally launch options
`LD_LIBRARY_PATH="/home/asus/.local/share/Steam/steamapps/common/DiRT Rally//lib/x86_64/" %command%`
But it is still giving that error and launcher didn't show up at all. Wİthout that command it is visible but game's are not running anyway.
But Medieval 2 and Shogun works 2 without workarounds. They're just running.
```>>> Adding process 3602 for game ID 310560
GameAction [AppID 310560, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
ERROR: ld.so: object '/home/asus/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 9: [: /home/asus/.local/share/Steam/ubuntu12_32/steam-runtime: unexpected operator
pid 3613 != 3612, skipping destruction (fork without exec?)
pid 3616 != 3612, skipping destruction (fork without exec?)
pid 3620 != 3612, skipping destruction (fork without exec?)
pid 3619 != 3612, skipping destruction (fork without exec?)
=== ERROR - You're missing vital libraries to run DiRT Rally
=== Either use the steam runtime or install these using your package manager
GameAction [AppID 310560, ActionID 1] : LaunchApp changed task to Completed with ""
>>> Adding process 3603 for game ID 310560
>>> Adding process 3604 for game ID 310560
librtmp.so.0 => not found
>>> Adding process 3605 for game ID 310560
>>> Adding process 3612 for game ID 310560
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/bin/DirtRally: error while loading shared libraries: librtmp.so.0: cannot open shared object file: No such file or directory
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 10: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[1]=SIGHUP(1): Program Hangup (GPU driver issue?): not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 11: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[2]=SIGINT(2): Program Interrupted: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 12: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[4]=SIGILL(4): Illegal instruction, check your CPU meets minimum requirements: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 13: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[6]=SIGABRT(6): Program Aborted: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 14: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[8]=SIGFPE(8): Floating-point exception, check your CPU meets minimum requirements: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 15: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[9]=SIGKILL(9): Program killed: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 16: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[11]=SIGSEGV(11): Segmentation fault: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 17: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[13]=SIGPIPE(13): Broken pipe, check networking: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 18: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[15]=SIGTERM(15): Program terminated: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 19: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[20]=SIGPWR(20): Program received power down signal: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 20: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: SIGNAL_MESSAGE[31]=SIGSYS(31): Bad system call: not found
/home/asus/.local/share/Steam/steamapps/common/DiRT Rally/DirtRally.sh: 22: /home/asus/.local/share/Steam/steamapps/common/DiRT Rally/config/post-run-check.sh: Bad substitution
>>> Adding process 3622 for game ID 310560
>>> Adding process 3623 for game ID 310560
>>> Adding process 3624 for game ID 310560
>>> Adding process 3625 for game ID 310560
Game removed: AppID 310560 "DiRT Rally", ProcID 3602
No cached sticky mapping in ActivateActionSet.Installing breakpad exception handler for appid(steam)/version(1508273419)
Generating new string page texture 118: 128x256, total string texture memory is 3,09 MB
Generating new string page texture 120: 384x256, total string texture memory is 3,48 MB
Generating new string page texture 121: 24x256, total string texture memory is 3,51 MB
GameAction [AppID 310560, ActionID 2] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 310560, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 310560, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 310560, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
GameAction[AppID 310560, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask: 0
Game update: AppID 310560 "DiRT Rally", ProcID 3634, IP 0.0.0.0:0
>>> Adding process 3634 for game ID 310560
GameAction [AppID 310560, ActionID 2] : LaunchApp changed task to WaitingGameWindow with ""
/bin/sh: 1: Rally//lib/x86_64/: not found
GameAction [AppID 310560, ActionID 2] : LaunchApp changed task to Completed with ""
>>> Adding process 3635 for game ID 310560
Game removed: AppID 310560 "DiRT Rally", ProcID 3634
I suspect about Prime to be honest but i’m not sure what to do about it.
generix
February 18, 2018, 12:41am
2
Considering all these strange problems you’re having, you should think about a fresh install. I presume your home dir is on the secondary hdd anyway? Do a standard install with en_US locale and a new user, then check if things work.
The only essential addition for your system is the changed acpi table from medakk.
Yep , my system works on ssd attached as / , and my home directory is on HDD. How this can lead to a problem like this?
I pm’ed meddak but he didn’t reply. Looks like he set his profile to not taking notifications.
generix
February 18, 2018, 1:44am
4
Having /home on a different drive doesn’t lead to problems, it just makes it easier to reinstall on the system drive.
Thanks for clarification.
How can i change that acpi table and where do i add acpi_windows 2009 at
gksu xed /etc/default/grub
