Using nvv4l2h264enc, with resolution 1256x612, encoding ends up with the following error:
ERROR src: nvv4l2h264enc0, msg: Failed to allocate required memory.
However, with resolution 1256x613, for instance, the pipeline works as expected.
…It also works with 612x1256.
Here are some resolutions, I have tested:
- 1256x608 OK
- 1256x609 FAIL
- 1256x610 FAIL
- 1256x611 FAIL
- 1256x612 FAIL
- 1256x613 OK
- 1256x614 OK
[…] - 1256x622 OK
- 1256x623 OK
Using GST_DEBUG=“v4l2*:7”, the following error log shows up:
0:00:00.214981135 28693 0x55a4dec320 ERROR v4l2allocator gstv4l2allocator.c:352:gst_v4l2_memory_group_new: buffer size 786432 is smaller then negotiated size 788736, this is usually the result of a bug in the v4l2 driver or libv4l.
0:00:00.215031409 28693 0x55a4dec320 ERROR v4l2bufferpool gstv4l2bufferpool.c:1156:gst_v4l2_buffer_pool_start:<nvv4l2h264enc0:pool:sink> we received 0 buffer from device '/dev/nvhost-msenc', we want at least 2
The error shows up this way using omxh264enc encoder:
ERROR src: omxh264enc-omxh264enc0, msg: Internal data stream error., dbg: /dvs/git/dirty/git-master_linux/3rdparty/gst/gst-omx/omx/gstomxvideoenc.c(1383): gst_omx_video_enc_loop (): /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0:stream stopped, reason not-negotiated
Using software encoding works as expected using any of those resolutions.
Are there any restrictions on the hardward encoding input resolution?
Thanks for your help
