When there are multiple joints in the top level body (the one right below ) in the MJCF file, some of them do not seem to be loaded. As a minimal working example:
<mujoco>
<worldbody>
<body name="root">
<joint name="x" type="slide" axis="1 0 0"/>
<joint name="y" type="slide" axis="0 1 0"/>
<joint name="z" type="slide" axis="0 0 1"/>
</body>
</worldbody>
</mujoco>
If this model file is loaded to Isaac Gym, for example using examples/asset_info.py, the output is
===== Actor: pincher =======================================
Bodies
['', '', 'root']
{'root': 2}
Joints
['z', 'x']
{'x': 1, 'z': 0}
Degrees Of Freedom (DOFs)
['z', 'x']
{'x': 1, 'z': 0}
Poses from Body State:
[((0., 0., 6.), (-0.7071068, 0., 0., 0.7071068))
((0., 0., 6.), (-0.7071068, 0., 0., 0.7071068))]
Velocities from Body State:
[((0., 0., 0.), (0., 0., 0.)) ((0., 0., 0.), (0., 0., 0.))
((0., 0., 0.), (0., 0., 0.))]
Body '' has position (0., 0., 6.)
Body 'root' has position (0., 0., 6.)
DOF states:
[(0., 0.) (0., 0.)]
DOF 'z' has position 0.0
DOF 'x' has position 0.0
and it can be seen that the y
joint has been skipped / ignored.
