When I try to use some functions of Docker or K8s on Nvidia TX2, I found there are some kernel configs are missing.
uname -a
gives:
Linux tx2 4.9.140-tegra #1 SMP PREEMPT Wed Mar 13 00:30:11 PDT 2019 aarch64 aarch64 aarch64 GNU/Linux
, and I was on JetPack 4.2
I used docker’s official kernel config checking script:
<b>nvidia@tx2:~$ wget https://raw.githubusercontent.com/moby/moby/master/contrib/check-config.sh</b>
--2019-07-17 10:00:48-- https://raw.githubusercontent.com/moby/moby/master/contrib/check-config.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.192.133, 151.101.128.133, 151.101.64.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.192.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 10337 (10K) [text/plain]
Saving to: ‘check-config.sh’
check-config.sh 100%[============================================================================================>] 10.09K --.-KB/s in 0.04s
2019-07-17 10:00:49 (225 KB/s) - ‘check-config.sh’ saved [10337/10337]
<b>nvidia@tx2:~$ bash check-config.sh</b>
info: reading kernel config from /proc/config.gz ...
Generally Necessary:
- cgroup hierarchy: properly mounted [/sys/fs/cgroup]
- CONFIG_NAMESPACES: enabled
- CONFIG_NET_NS: enabled
- CONFIG_PID_NS: enabled
- CONFIG_IPC_NS: enabled
- CONFIG_UTS_NS: enabled
- CONFIG_CGROUPS: enabled
- CONFIG_CGROUP_CPUACCT: enabled
- CONFIG_CGROUP_DEVICE: enabled
- CONFIG_CGROUP_FREEZER: enabled
- CONFIG_CGROUP_SCHED: enabled
- CONFIG_CPUSETS: enabled
- CONFIG_MEMCG: enabled
- CONFIG_KEYS: enabled
- CONFIG_VETH: enabled (as module)
- CONFIG_BRIDGE: enabled
- CONFIG_BRIDGE_NETFILTER: enabled (as module)
- CONFIG_NF_NAT_IPV4: enabled (as module)
- CONFIG_IP_NF_FILTER: enabled (as module)
- CONFIG_IP_NF_TARGET_MASQUERADE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_CONNTRACK: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_IPVS: enabled (as module)
- CONFIG_IP_NF_NAT: enabled (as module)
- CONFIG_NF_NAT: enabled (as module)
- CONFIG_NF_NAT_NEEDED: enabled
- CONFIG_POSIX_MQUEUE: enabled
Optional Features:
- CONFIG_USER_NS: enabled
- CONFIG_SECCOMP: enabled
- CONFIG_CGROUP_PIDS: enabled
- CONFIG_MEMCG_SWAP: enabled
- CONFIG_MEMCG_SWAP_ENABLED: enabled
(cgroup swap accounting is currently enabled)
- CONFIG_BLK_CGROUP: enabled
- CONFIG_BLK_DEV_THROTTLING: enabled
- CONFIG_IOSCHED_CFQ: enabled
<b>- CONFIG_CFQ_GROUP_IOSCHED: missing</b>
- CONFIG_CGROUP_PERF: enabled
<b>- CONFIG_CGROUP_HUGETLB: missing</b>
- CONFIG_NET_CLS_CGROUP: enabled
- CONFIG_CGROUP_NET_PRIO: enabled
- CONFIG_CFS_BANDWIDTH: enabled
- CONFIG_FAIR_GROUP_SCHED: enabled
- CONFIG_RT_GROUP_SCHED: enabled
<b>- CONFIG_IP_NF_TARGET_REDIRECT: missing</b>
- CONFIG_IP_VS: enabled (as module)
- CONFIG_IP_VS_NFCT: enabled
<b>- CONFIG_IP_VS_PROTO_TCP: missing</b>
<b>- CONFIG_IP_VS_PROTO_UDP: missing</b>
- CONFIG_IP_VS_RR: enabled (as module)
- CONFIG_EXT4_FS: enabled
- CONFIG_EXT4_FS_POSIX_ACL: enabled
- CONFIG_EXT4_FS_SECURITY: enabled
- Network Drivers:
- "overlay":
- CONFIG_VXLAN: enabled
- CONFIG_BRIDGE_VLAN_FILTERING: enabled
Optional (for encrypted networks):
- CONFIG_CRYPTO: enabled
- CONFIG_CRYPTO_AEAD: enabled
- CONFIG_CRYPTO_GCM: enabled
- CONFIG_CRYPTO_SEQIV: enabled
- CONFIG_CRYPTO_GHASH: enabled
- CONFIG_XFRM: enabled
- CONFIG_XFRM_USER: enabled
- CONFIG_XFRM_ALGO: enabled
<b> - CONFIG_INET_ESP: missing</b>
- CONFIG_INET_XFRM_MODE_TRANSPORT: enabled
- "ipvlan":
<b> - CONFIG_IPVLAN: missing</b>
- "macvlan":
- CONFIG_MACVLAN: enabled (as module)
- CONFIG_DUMMY: enabled
- "ftp,tftp client in container":
- CONFIG_NF_NAT_FTP: enabled (as module)
- CONFIG_NF_CONNTRACK_FTP: enabled (as module)
- CONFIG_NF_NAT_TFTP: enabled (as module)
- CONFIG_NF_CONNTRACK_TFTP: enabled (as module)
- Storage Drivers:
- "aufs":
<b> - CONFIG_AUFS_FS: missing</b>
- "btrfs":
- CONFIG_BTRFS_FS: enabled (as module)
- CONFIG_BTRFS_FS_POSIX_ACL: enabled
- "devicemapper":
- CONFIG_BLK_DEV_DM: enabled
<b> - CONFIG_DM_THIN_PROVISIONING: missing</b>
- "overlay":
- CONFIG_OVERLAY_FS: enabled (as module)
- "zfs":
- /dev/zfs: missing
- zfs command: missing
- zpool command: missing
Limits:
- /proc/sys/kernel/keys/root_maxkeys: 1000000
Especially for this config: CONFIG_IP_NF_TARGET_REDIRECT
Will these kernel configs be enabled officially? or how can I enable them manually?
