We found some ONNX layers cannot be parsed by TensorRT, but in TensorRT ONNX support Matrix it says these layers can be supported. Please help to check below issues
1 Argmax
[i]onnx: v.onnx
fp16
Input filename: v.onnx
ONNX IR version: 0.0.5
Opset version: 10
Producer name: PaddlePaddle
Producer version:
Domain:
Model version: 0
Doc string:
WARNING: ONNX model has a newer ir_version (0.0.5) than this parser was built against (0.0.3).
While parsing node number 68 [ArgMax -> “arg_max_0.tmp_0@argmax”]:
ERROR: /home/erisuser/p4sw/sw/gpgpu/MachineLearning/DIT/release/5.0/parsers/onnxOpenSource/ModelImporter.cpp:142 In function importNode:
[8] No importer registered for op: ArgMax
failed to parse onnx file
Engine could not be created
Engine could not be created[/i]
2 Reshape
[i]onnx: dr_diagnosis.onnx
fp16
Input filename: d.onnx
Opset version: 10
Producer version:
Domain:
Model version: 0
Doc string:
While parsing node number 428 [Reshape -> “bilinear_pooling_reshape_2D.tmp_0”]:
ERROR: /home/erisuser/p4sw/sw/gpgpu/MachineLearning/DIT/release/5.0/parsers/onnxOpenSource/builtin_op_importers.cpp:1314 In function importReshape:
[8] Assertion failed: get_shape_size(new_shape) == get_shape_size(tensor.getDimensions())
3 Add
[i]onnx: l.onnx
fp16
Input filename: l.onnx
Opset version: 10
Producer version:
Domain:
Model version: 0
Doc string:
While parsing node number 3 [Add -> “conv1.tmp_1”]:
ERROR: /home/erisuser/p4sw/sw/gpgpu/MachineLearning/DIT/release/5.0/parsers/onnxOpenSource/builtin_op_importers.cpp:328 In function importAdd:
[8] Assertion failed: get_shape_size(shift_weights.shape) == get_shape_size(dims)
4 matmul
when running to matmul layer, it reports segment fault
Please help to check above issues
