when I installed JP in my host computer, something wrong happened. Because it is not allowed to put picture here, I will giva a link which I put the screemshot there.
I can’t see the image, but a VM is typically a problem with the USB communications. If there was some sort of communications error, then perhaps look for a way to increase the VM’s USB buffer and explicitly set the recovery mode Jetson as pass-through to the VM in USB2 mode.
Looks like the profile picture is clipped to the size of the needed image and only includes a tiny upper right piece of the image, so no useful information.
There is a way to post an image, though not all formats are supported. One is to edit an existing post, the other is availabe when you post a new message.
If you hover your mouse over the upper right of one of your existing posts you will see a quote ["] icon, and if the mouse is over that icon some other icons show up. The one which looks like a pencil allows you to edit an existing post.
Once you are editing an existing post or creating a new post notice that the upper right icons in the tool bar for that message contain a block quote icon (“</>”), a URL icon (looks like a chain link or diagonal infinity symbol), and between those something which sort of looks like a picture frame. This picture frame icon is the image tool. If the image tool won’t accept one image format you can try another.
