Ignore this error. It’s just a character encoding problem for a certain sample.
You can export the .nsys-rep file to host.
It’s not problem about deepstream sdk,you can get support in developer tools forum.
Thanks, I will try it later.
I’ sorry to bother you again, but I’m not understand the branch group clearly, could you give me a more detailed explanation about it, thanks.
1.gie-unique-id
is the identifier of each infer engine and is unique.
and pgie-id
in branch[X]
group must be same as this value.
Just ensure it is unique, no matter what the value is, it can be 42
2.About src-ids
The parallel-app has multiple stream inputs.
If you want to send different stream inputs to different inference branches, configure the corresponding stream id.
Such as
0;1;2 --> branch0
1;2;3 --> branch1
4;5;6(if you have bigger than 7 inputs stream) --> branch2.
Is the numbers of 0;1;2 in branch0 fixed? Just like:
0;1;2 --> branch0 (branch0 src-id can't be 1;2;3 )
1;2;3 --> branch1
4;5;6 --> branch2
7;8;9 --> branch3
And I found the source was provided by the csv file in source4_1080.p_dec_parallel_infer.yml
No,any valid id can be used
Just related to their order and num-sources
Sorry, please forgive my stupidity, I still not clearly understand it. Taking source4_1080p_dec_parallel_infer.yml as example:
branch0:
## pgie's id
pgie-id: 1 --> primary-gie0 --> the model is yolov4
## select sources by sourceid
src-ids: 0;1;2
branch1:
## pgie's id
pgie-id: 2 --> primary-gie1 --> the model is bodypose2d
src-ids: 1;2;3
branch2:
## pgie's id
pgie-id: 3 --> primary-gie2 --> the model is trafficcamnet
src-ids: 1;2;3
And the sources are provided: sources_4_different_source.csv
The csv file provides 2 sources,and each source’s num-sources equal = 2, thus, there are a total of 4 channels of video. I can understand that 0;1 in the src-id is the first source :file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
split into two videos, and 2 is the second source file:///opt/ nvidia/deepstream/deepstream/samples/streams/sample_1080p_h265.mp4
split the two-way video in the first well
Your understanding is completely correct.
you can generate the pipeline graph through GST_DEBUG_DUMP_DOT_DIR.
I get the pipeline.png by using the follow command:
apt-get install graphviz
export GST_DEBUG_DUMP_DOT_DIR=/tmp/
./apps/deepstream-parallel-infer/deepstream-parallel-infer -c
configs/apps/bodypose_yolo_lpr/source4_1080p_dec_parallel_infer.yml
cd /tmp/
But I’m confused about pipeline.png, why is there only one src in tee?
The data format processed by nvinfer
is called batch.
And nvstreammux
organizes video frames into batches. then the batch is forked to every branch through tee
You had better read the documentation about the nstreammux and nvinfer.
