I’m developing sensor driver and trying to display ISP processing data.
I use gstreamer with the nvarguscamerasrc plugin, but some errors and warnings occured.
Jan 28 23:40:26 jetson-0423218010774 nvargus-daemon[5788]: === gst-launch-1.0[7742]: Connection established (7F7C6E41D0)
Jan 28 23:40:26 jetson-0423218010774 kernel: [ 112.757513] tegra194-isp5 14800000.isp: isp_channel_power_on
Jan 28 23:40:26 jetson-0423218010774 kernel: [ 112.761796] tegra194-isp5 14800000.isp: 6 GoS tables configured.
Jan 28 23:40:26 jetson-0423218010774 kernel: [ 112.761809] tegra194-isp5 14800000.isp: gos[0] = 0xeca00000
Jan 28 23:40:26 jetson-0423218010774 kernel: [ 112.761827] tegra194-isp5 14800000.isp: gos[1] = 0xeca01000
Jan 28 23:40:26 jetson-0423218010774 kernel: [ 112.761832] tegra194-isp5 14800000.isp: gos[2] = 0xeca02000
Jan 28 23:40:26 jetson-0423218010774 kernel: [ 112.761835] tegra194-isp5 14800000.isp: gos[3] = 0xeca03000
Jan 28 23:40:26 jetson-0423218010774 kernel: [ 112.761839] tegra194-isp5 14800000.isp: gos[4] = 0xeca04000
Jan 28 23:40:26 jetson-0423218010774 kernel: [ 112.761842] tegra194-isp5 14800000.isp: gos[5] = 0xeca05000
Jan 28 23:40:26 jetson-0423218010774 kernel: [ 112.797158] [RCE] Total number of isp channels : 16
Jan 28 23:40:26 jetson-0423218010774 nvargus-daemon[5788]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Jan 28 23:40:26 jetson-0423218010774 nvargus-daemon[5788]: NvPclHwGetModuleList: No module data found
Jan 28 23:40:27 jetson-0423218010774 nvargus-daemon[5788]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jan 28 23:40:27 jetson-0423218010774 nvargus-daemon[5788]: ---- imager: No override file found. ----
Jan 28 23:40:27 jetson-0423218010774 nvargus-daemon[5788]: LSC: LSC surface is not based on full res!
Jan 28 23:40:27 jetson-0423218010774 nvargus-daemon[5788]: === gst-launch-1.0[7742]: CameraProvider initialized (0x7f7463ef90)
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.362400] tegra194-vi5 15c10000.vi: vi_channel_power_on_vi_device
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.362606] tegra194-vi5 15c10000.vi: 6 GoS tables configured.
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.362623] tegra194-vi5 15c10000.vi: gos[0] = 0xeca00000
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.362627] tegra194-vi5 15c10000.vi: gos[1] = 0xeca01000
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.362632] tegra194-vi5 15c10000.vi: gos[2] = 0xeca02000
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.362636] tegra194-vi5 15c10000.vi: gos[3] = 0xeca03000
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.362640] tegra194-vi5 15c10000.vi: gos[4] = 0xeca04000
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.362643] tegra194-vi5 15c10000.vi: gos[5] = 0xeca05000
Jan 28 23:40:27 jetson-0423218010774 gnome-software[7600]: failed to call gs_plugin_refresh on fwupd: [*/cabinet/*/source/fwupd/*] failed to download https://cdn.fwupd.org/downloads/firmware.xml.gz.asc: Cannot resolve hostname
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.413142] [RCE] vi5_hwinit: firmware CL2018061801 protocol version 2.2
Jan 28 23:40:27 jetson-0423218010774 gnome-software[7600]: failed to call gs_plugin_add_installed on shell-extensions: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.gnome.Shell.Extensions' on object at path /org/gnome/Shell
Jan 28 23:40:27 jetson-0423218010774 gnome-software[7600]: Only 0 apps for recent list, hiding
Jan 28 23:40:27 jetson-0423218010774 kernel: [ 113.856042] tegra194-vi5 15c10000.vi: vi_channel_power_off_vi_device
I think that device-tree has a mistake, but please tell me where to check.
And an error occured at PWL setting.
Jan 28 23:40:31 jetson-0423218010774 nvargus-daemon[5788]: SCF: Error InvalidState: Number of control points, more than expected (in src/services/capture/NvCaptureViCsiHw.cpp, function updateViCsiResolution(), line 327)
Jan 28 23:40:31 jetson-0423218010774 nvargus-daemon[5788]: SCF: Error InvalidState: (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function setMode(), line 434)
Jan 28 23:40:31 jetson-0423218010774 nvargus-daemon[5788]: SCF: Error InvalidState: (propagating from src/services/capture/CaptureRecord.cpp, function updateMode(), line 438)
Jan 28 23:40:31 jetson-0423218010774 nvargus-daemon[5788]: SCF: Error InvalidState: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1105)
Jan 28 23:40:31 jetson-0423218010774 nvargus-daemon[5788]: SCF: Error InvalidState: (propagating from src/common/Utils.cpp, function workerThread(), line 116)
Jan 28 23:40:31 jetson-0423218010774 nvargus-daemon[5788]: SCF: Error InvalidState: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
Jan 28 23:40:31 jetson-0423218010774 nvargus-daemon[5788]: SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 637)
Jan 28 23:40:31 jetson-0423218010774 nvargus-daemon[5788]: SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 358)
The PWL setting is same as TX2, so are there any restrictions on settings?
