Hi, ALL.
I am studying the code of libgdsync recently and find a structure CUstreamBatchMemOpParams not the same as in cuda 8.0.61.
In my cuda version 8.0.61, it defined like this in cuda.h as below
typedef union CUstreamBatchMemOpParams_union {
CUstreamBatchMemOpType operation;
struct CUstreamMemOpWaitValueParams_st {
CUdeviceptr address;
union {
cuuint32_t value;
cuuint64_t pad;
unsigned int flags;
CUdeviceptr alias; /**< For driver internal use. Initial value is unimportant. */
} waitValue;
struct CUstreamMemOpWriteValueParams_st {
union {
cuuint32_t value;
cuuint64_t pad;
unsigned int flags;
} writeValue;
struct CUstreamMemOpFlushRemoteWritesParams_st {
unsigned int flags;
} flushRemoteWrites;
cuuint64_t pad[6];
} CUstreamBatchMemOpParams;
but in the code of libgdsync, it infers a member named “inlineCopy” which is not exist in my CUstreamBatchMemOpParams.
static int gds_fill_inlcpy(CUstreamBatchMemOpParams *param, CUdeviceptr addr, void *data, size_t n_bytes, int flags)
int retcode = 0;
#if GDS_HAS_INLINE_COPY
CUdeviceptr dev_ptr = addr;
assert(addr);
assert(n_bytes > 0);
// TODO:
// verify address requirements of inline_copy
//assert((((unsigned long)addr) & 0x3) == 0);
bool need_barrier = (flags & GDS_IMMCOPY_POST_TAIL_FLUSH ) ? true : false;
param->operation = CU_STREAM_MEM_OP_INLINE_COPY;
param->inlineCopy.byteCount = n_bytes;
param->inlineCopy.srcData = data;
param->inlineCopy.address = dev_ptr;
param->inlineCopy.flags = CU_STREAM_INLINE_COPY_NO_MEMORY_BARRIER;
if (need_barrier)
param->inlineCopy.flags = 0;
gds_dbg("op=%d addr=%p src=%p size=%zd flags=%08x\n",
param->operation,
(void*)param->inlineCopy.address,
param->inlineCopy.srcData,
param->inlineCopy.byteCount,
param->inlineCopy.flags);
#else
gds_err("error, inline copy is unsupported\n");
retcode = EINVAL;
#endif
return retcode;
So, I wonder if the cuda libgdsync using is not the cuda which has been published ? Or something I have missed there ?
Thanks for your help.
