Some questions when running samples in Deepstream
Jetson
• DeepStream Version
5.0
4.4
• TensorRT Version
7.1
questions
When I run “deepstream_app_source1_dashcamnet_vehiclemakenet_vehicletypenet.txt” in Deepstream, I found that the pipeline needs to first convert the etlt file into an engine file, which will take a long time. So I wanted to use tlt-converter on Jetson platform to generate the courtesy file, but the following error occurred:
any idea?thanks.
Hi,can anyone give some suggestions?
Someone solved this problem typing with:
chmod +x tlt-converter
The main guide:
https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/text/deploying_to_deepstream.html#instructions-for-jetson
Please check the key is correct.
The “-k” option should be the correct key.
