Some samples from tao_others doesn’t work on Nvidia Jetson AGX Orin 32 GB (dev kit) after firmware update to 4 GB version emulation mode (Jetson Orin Nano 4 GB).
launch apps/tao_detection samples
for example, ./apps/tao_detection/ds-tao-detection -c configs/TrafficCamNet/traffic_cam_config.txt -i file:////home/dev/projects/deepstream_tao_apps/1.MOV
It doesn’t work by default but launches after replacement to codec x264enc
enc = gst_element_factory_make (“nvv4l2h264enc”, “h264-enc”);
enc = gst_element_factory_make (“x264enc”, “h264-enc”);
replace codec to x264 and launch sample from tao_other - get an error
./deepstream-faciallandmark-app 1 …/…/…/configs/facial_tao/sample_faciallandmarks_config.txt file:////home/dev/projects/deepstream_tao_apps/gaze.mp4 …/…/…/faciallandmark
dev@dev-desktop:~/projects/deepstream_tao_apps/apps/tao_others/deepstream-faciallandmark-app$ ./deepstream-faciallandmark-app 1 …/…/…/configs/facial_tao/sample_faciallandmarks_config.txt file:////home/dev/projects/deepstream_tao_apps/gaze.mp4 …/…/…/faciallandmark
Request sink_0 pad from streammux
OSD and sink elements link failure.
It means that an error “codec was not found” occured on launch, so we changed codec to x264enc.
But when we launch tao_others samples with x264enc codec we get another error "OSD and sink elements link failure. "
It should work by default. Also, you mention that it happens after firmware update to 4 GB version emulation mode. I assume that it was working before firmware update.
Suggest you use an l4t deepstream docker to test inside it again.
If you still meet error again, please create forum topic in deepstream forum instead to get further help.
