Some troubles with cuda driver api in 64-bit mode
Hi everyone!
I’m beginner in cuda development. I wrote a simple cuda program, using CUDA driver API, that perfectly works. But only when I compile it as 32-bit application.
The main program looks like this:
#include<stdio.h>
#include<cuda.h>
int main()
  CUdevice dev;
  CUcontext context;
  CUmodule module;
  CUfunction func;
  CUdeviceptr d_data;
  float h_data[10];
  int N=10;
  for(int i=0;i<N;i++)h_data[i]=i+1;
  cuInit(0);
  cuDeviceGet(&dev,0);
  cuCtxCreate(&context,0,dev);
  cuModuleLoad(&module,"test.cubin");
  printf("Get function code: %d\n", cuModuleGetFunction(&func,module,"square"));
  cuMemAlloc(&d_data,sizeof(float)*N);
  cuMemcpyHtoD(d_data,h_data,sizeof(float)*N);
  cuParamSeti(func,0,d_data);
  cuParamSetSize(func,4);
  cuFuncSetBlockShape(func,N,1,1);
  cuLaunchGrid(func,1,1);
  cuMemcpyDtoH(h_data,d_data,sizeof(float)*N);
  for(int i=0;i<N;i++)printf("%d: %f\n", i, h_data[i]);
  return 0;
Here is the GPU program(test.cu)
extern "C" {
__global__ void square(volatile float* const a)
	a[threadIdx.x] = a[threadIdx.x]*a[threadIdx.x];
And here is my Makefile:
CUDAINC = "C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\include"
CUDALIB = "C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\lib\x64"
all:
		cl /c -I$(CUDAINC)  test.cpp
		link /LIBPATH:$(CUDALIB) test.obj cuda.lib
The test.cu file I compile with the followed command:
nvcc --cubin -m 32 -arch sm_21 test.cu
If I compile this as 32-bit application, the output is exactly as expected. But if I compile it as 64-bit application, the output is the same as input. In other words, the input is unchanged. Of course, I make some changes in makefile and GPU program I compile with another command(-m 64 instead of -m 32) Moreover, I make changes in source file:
cuParamSetSize(func,8) instead of cuParamSetSize(func, 4)…
So… Does anybody have any idea about what can I do wrong ?
Step one: check your errors. You can’t load a 32-bit cubin in a 64-bit application.
Step two: use cuLaunchKernel in 4.0. It’s ~1300x better than the old driver API means of launching a kernel.
Thank you very much for quick reply!
to step one:
Of course, I loaded 64-bit cubin in 64-bit application and all function calls returned 0…
to step two:
cuKernelLaunch works fine! So, thank you again :)
