some wrong values in texture (using tex2D)
Hi all. I’m a newbie here, please help me.
I’m storing 80x160 float data into a 2D texture using the following code
texture<float, 2, cudaReadModeElementType> tex;
float * landdata;
cudaArray* cu_array;
cudaChannelFormatDesc channelDesc;
unsigned int size = meshW * meshH * sizeof(float);
channelDesc = cudaCreateChannelDesc(32, 0, 0, 0,cudaChannelFormatKindFloat);
cutilSafeCall( cudaMallocArray( &cu_array, &channelDesc, meshW, meshH ));
cutilSafeCall( cudaMemcpyToArray( cu_array, 0, 0, landdata, size, cudaMemcpyHostToDevice));
tex.addressMode[0] = cudaAddressModeWrap;
tex.addressMode[1] = cudaAddressModeWrap;
tex.filterMode = cudaFilterModePoint;
tex.normalized = true;
cudaBindTextureToArray( tex, cu_array, channelDesc);
// read texture in kernel
__global__ void landKernel(float4* pos, unsigned int width, unsigned int height)
unsigned int i = blockIdx.x*blockDim.x + threadIdx.x;
unsigned int j = blockIdx.y*blockDim.y + threadIdx.y;
//calculate pos coordinates
float posi = i / (float) width;
float posj = j / (float) height;
float y = tex2D(tex, posi, posj);
but I’ve checked it contains some wrong values. Could you tell me where I’m going wrong ? Currently, I’m using a GeForce 8400M G 128MB.
argh… it’s solved now. :D
