When I run the demo isaac_ros_cumotion_moveit in isaac_ros_cumotion_moveit — isaac_ros_docs documentation , I set up MoveIt 2 with cuMotion using UR but got the following result and plan & execute failed. But I use the robot franka and it succeeded.
[ERROR] [1778209746.834594017] [cumotion_action_server]: joint_state was not received from /joint_states
Hello @2287278570,
Thanks for posting in the Isaac ROS forum!
Are you using a physical UR, simulated UR (Isaac Sim or Gazebo), or no robot at all?
Please check the Note in this Using the cuMotion Planner in MoveIt section.
The MoveIt configuration for Franka includes such emulation via a “fake hardware” interface, but the same is not true for UR, which would require an external simulator such as URSim.
The error you provided means cumotion_action_server is subscribed to /joint_states but nothing is publishing on that topic in your UR setup.
If you don’t have a physical UR (or don’t want to use one for testing), bring up the UR driver in mock hardware mode:
ros2 launch ur_robot_driver ur_control.launch.py ur_type:=ur10e robot_ip:=0.0.0.0 use_mock_hardware:=true
(For Humble UR driver versions usually use use_fake_hardware:=true instead.)
This brings up the controller_manager + joint_state_broadcaster against mock hardware, so /joint_states is published exactly as on a real robot, and cuMotion can plan against it.
Verify with:
ros2 control list_controllers # should list joint_state_broadcaster active
ros2 topic echo /joint_states --once # should print joint positions
If you need real-robot motion, then yes, connect to the UR, set robot_ip:=<your_ur_ip>, and run the External Control program on the teach pendant.
When I run ros2 launch isaac_ros_cumotion_examples ur_isaac_sim.launch.py ur_type:=ur10e in Tutorial for cuMotion MoveIt Plugin with Isaac Sim — isaac_ros_docs documentation, and I got the following error.
admin@byd123-System-Product-Name:/workspaces/isaac_ros-dev$ ros2 launch isaac_ros_cumotion_examples ur_isaac_sim.launch.py ur_type:=ur10e
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2026-05-15-10-04-30-015714-byd123-System-Product-Name-21041
[INFO] [launch]: Default logging verbosity is set to INFO
WARNING:root:Cannot infer URDF from /opt/ros/humble/share/ur_moveit_config. – using config/ur10e.urdf
WARNING:root:Cannot infer SRDF from /opt/ros/humble/share/ur_moveit_config. – using config/ur10e.srdf
[INFO] [rviz2-1]: process started with pid [21042]
[INFO] [robot_state_publisher-2]: process started with pid [21044]
[INFO] [static_transform_publisher-3]: process started with pid [21046]
[INFO] [move_group-4]: process started with pid [21048]
[INFO] [ros2_control_node-5]: process started with pid [21050]
[INFO] [spawner-6]: process started with pid [21052]
[INFO] [spawner-7]: process started with pid [21054]
[INFO] [spawner-8]: process started with pid [21056]
[INFO] [cumotion_planner_node-9]: process started with pid [21058]
[robot_state_publisher-2] [INFO] [1778810670.262503189] [robot_state_publisher]: got segment base
[robot_state_publisher-2] [INFO] [1778810670.262606909] [robot_state_publisher]: got segment base_link
[robot_state_publisher-2] [INFO] [1778810670.262613368] [robot_state_publisher]: got segment base_link_inertia
[robot_state_publisher-2] [INFO] [1778810670.262617064] [robot_state_publisher]: got segment flange
[robot_state_publisher-2] [INFO] [1778810670.262620281] [robot_state_publisher]: got segment forearm_link
[robot_state_publisher-2] [INFO] [1778810670.262623409] [robot_state_publisher]: got segment ft_frame
[robot_state_publisher-2] [INFO] [1778810670.262626544] [robot_state_publisher]: got segment shoulder_link
[robot_state_publisher-2] [INFO] [1778810670.262629592] [robot_state_publisher]: got segment tool0
[robot_state_publisher-2] [INFO] [1778810670.262632761] [robot_state_publisher]: got segment upper_arm_link
[robot_state_publisher-2] [INFO] [1778810670.262635856] [robot_state_publisher]: got segment world
[robot_state_publisher-2] [INFO] [1778810670.262638846] [robot_state_publisher]: got segment wrist_1_link
[robot_state_publisher-2] [INFO] [1778810670.262641916] [robot_state_publisher]: got segment wrist_2_link
[robot_state_publisher-2] [INFO] [1778810670.262644861] [robot_state_publisher]: got segment wrist_3_link
[ros2_control_node-5] [INFO] [1778810670.264251345] [controller_manager]: Subscribing to ‘~/robot_description’ topic for robot description file.
[static_transform_publisher-3] [INFO] [1778810670.264341546] [static_transform_publisher]: Spinning until stopped - publishing transform
[static_transform_publisher-3] translation: (‘0.000000’, ‘0.000000’, ‘0.000000’)
[static_transform_publisher-3] rotation: (‘0.000000’, ‘0.000000’, ‘0.000000’, ‘1.000000’)
[static_transform_publisher-3] from ‘world’ to ‘base_link’
[ros2_control_node-5] [INFO] [1778810670.265228043] [controller_manager]: update rate is 100 Hz
[ros2_control_node-5] [INFO] [1778810670.265255047] [controller_manager]: Spawning controller_manager RT thread with scheduler priority: 50
[ros2_control_node-5] [WARN] [1778810670.265335640] [controller_manager]: Could not enable FIFO RT scheduling policy: with error number <1>(Operation not permitted). See [ Controller Manager — ROS2_Control: Rolling May 2026 documentation ] for details on how to enable realtime scheduling.
[rviz2-1] QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-admin’
[ros2_control_node-5] [INFO] [1778810670.275626742] [controller_manager]: Received robot description file.
[ros2_control_node-5] [INFO] [1778810670.275861728] [resource_manager]: Loading hardware ‘URFakeSystem’
[ros2_control_node-5] [INFO] [1778810670.276749989] [resource_manager]: Initialize hardware ‘URFakeSystem’
[move_group-4] Error: Semantic description is not specified for the same robot as the URDF
[move_group-4] at line 681 in ./src/model.cpp
[move_group-4] [INFO] [1778810670.281912895] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0 seconds
[move_group-4] [INFO] [1778810670.282009133] [moveit_robot_model.robot_model]: Loading robot model ‘ur10e’…
[move_group-4] [INFO] [1778810670.282019316] [moveit_robot_model.robot_model]: No root/virtual joint specified in SRDF. Assuming fixed joint
[ros2_control_node-5] [INFO] [1778810670.283768109] [resource_manager]: Successful initialization of hardware ‘URFakeSystem’
[ros2_control_node-5] [INFO] [1778810670.283854874] [resource_manager]: ‘configure’ hardware ‘URFakeSystem’
[ros2_control_node-5] [INFO] [1778810670.283866525] [resource_manager]: Successful ‘configure’ of hardware ‘URFakeSystem’
[ros2_control_node-5] [INFO] [1778810670.283875963] [resource_manager]: ‘activate’ hardware ‘URFakeSystem’
[ros2_control_node-5] [INFO] [1778810670.283881705] [resource_manager]: Successful ‘activate’ of hardware ‘URFakeSystem’
[move_group-4] [INFO] [1778810670.333659694] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Publishing maintained planning scene on ‘monitored_planning_scene’
[move_group-4] [INFO] [1778810670.333816227] [moveit.ros_planning_interface.moveit_cpp]: Listening to ‘joint_states’ for joint states
[move_group-4] [INFO] [1778810670.335082772] [moveit_ros.current_state_monitor]: Listening to joint states on topic ‘joint_states’
[move_group-4] [INFO] [1778810670.335811110] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to ‘/attached_collision_object’ for attached collision objects
[move_group-4] [INFO] [1778810670.335822189] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
[move_group-4] [INFO] [1778810670.338756835] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to ‘/planning_scene’
[move_group-4] [INFO] [1778810670.338770080] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting world geometry update monitor for collision objects, attached objects, octomap updates.
[move_group-4] [INFO] [1778810670.338961511] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to ‘collision_object’
[move_group-4] [INFO] [1778810670.339128303] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to ‘planning_scene_world’ for planning scene world geometry
[move_group-4] [WARN] [1778810670.339343581] [moveit.ros.occupancy_map_monitor.middleware_handle]: Resolution not specified for Octomap. Assuming resolution = 0.1 instead
[move_group-4] [ERROR] [1778810670.339352354] [moveit.ros.occupancy_map_monitor.middleware_handle]: No 3D sensor plugin(s) defined for octomap updates
[move_group-4] [INFO] [1778810670.342837641] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline ‘isaac_ros_cumotion’
[move_group-4] [WARN] [1778810670.343522950] [pluginlib.ClassLoader]: given plugin name ‘libisaac_ros_cumotion_moveit’ should be ‘isaac_ros_cumotion_moveit’ for better portability
[move_group-4] [INFO] [1778810670.357485134] [moveit.ros_planning.planning_pipeline]: Using planning interface ‘Generate minimum-jerk trajectories using NVIDIA Isaac ROS cuMotion’
[move_group-4] [INFO] [1778810670.358768022] [moveit_ros.fix_workspace_bounds]: Param ‘isaac_ros_cumotion.default_workspace_bounds’ was not set. Using default value: 10.000000
[move_group-4] [INFO] [1778810670.358790901] [moveit_ros.fix_start_state_bounds]: Param ‘isaac_ros_cumotion.start_state_max_bounds_error’ was set to 0.100000
[move_group-4] [INFO] [1778810670.358795314] [moveit_ros.fix_start_state_bounds]: Param ‘isaac_ros_cumotion.start_state_max_dt’ was not set. Using default value: 0.500000
[move_group-4] [INFO] [1778810670.358804031] [moveit_ros.fix_start_state_collision]: Param ‘isaac_ros_cumotion.start_state_max_dt’ was not set. Using default value: 0.500000
[move_group-4] [INFO] [1778810670.358807632] [moveit_ros.fix_start_state_collision]: Param ‘isaac_ros_cumotion.jiggle_fraction’ was not set. Using default value: 0.020000
[move_group-4] [INFO] [1778810670.358811386] [moveit_ros.fix_start_state_collision]: Param ‘isaac_ros_cumotion.max_sampling_attempts’ was not set. Using default value: 100
[move_group-4] [INFO] [1778810670.358819942] [moveit.ros_planning.planning_pipeline]: Using planning request adapter ‘Fix Workspace Bounds’
[move_group-4] [INFO] [1778810670.358822733] [moveit.ros_planning.planning_pipeline]: Using planning request adapter ‘Fix Start State Bounds’
[move_group-4] [INFO] [1778810670.358825168] [moveit.ros_planning.planning_pipeline]: Using planning request adapter ‘Fix Start State In Collision’
[move_group-4] [INFO] [1778810670.358827650] [moveit.ros_planning.planning_pipeline]: Using planning request adapter ‘Fix Start State Path Constraints’
[move_group-4] [INFO] [1778810670.364940043] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline ‘ompl’
[move_group-4] [INFO] [1778810670.365563936] [moveit.ros_planning.planning_pipeline]: Multiple planning plugins available. You should specify the ‘~planning_plugin’ parameter. Using ‘chomp_interface/CHOMPPlanner’ for now.
[move_group-4] [INFO] [1778810670.366650322] [moveit.ros_planning.planning_pipeline]: Using planning interface ‘CHOMP’
[move_group-4] [INFO] [1778810670.412267993] [moveit.plugins.moveit_simple_controller_manager]: Added FollowJointTrajectory controller for scaled_joint_trajectory_controller
[move_group-4] [INFO] [1778810670.422545786] [moveit.plugins.moveit_simple_controller_manager]: Added FollowJointTrajectory controller for joint_trajectory_controller
[move_group-4] [INFO] [1778810670.422709539] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
[move_group-4] [INFO] [1778810670.422734825] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
[move_group-4] [INFO] [1778810670.424824883] [moveit_ros.trajectory_execution_manager]: Trajectory execution is managing controllers
[move_group-4] [INFO] [1778810670.424844166] [move_group.move_group]: MoveGroup debug mode is ON
[move_group-4] [INFO] [1778810670.466163435] [move_group.move_group]:
[move_group-4]
[move_group-4] ********************************************************
[move_group-4] * MoveGroup using:
[move_group-4] * - ApplyPlanningSceneService
[move_group-4] * - ClearOctomapService
[move_group-4] * - CartesianPathService
[move_group-4] * - ExecuteTrajectoryAction
[move_group-4] * - GetPlanningSceneService
[move_group-4] * - KinematicsService
[move_group-4] * - MoveAction
[move_group-4] * - MotionPlanService
[move_group-4] * - QueryPlannersService
[move_group-4] * - StateValidationService
[move_group-4]
[move_group-4] [INFO] [1778810670.466205739] [moveit_move_group_capabilities_base.move_group_context]: MoveGroup context using planning plugin isaac_ros_cumotion_moveit/CumotionPlanner
[move_group-4] [INFO] [1778810670.466215116] [moveit_move_group_capabilities_base.move_group_context]: MoveGroup context initialization complete
[move_group-4] Loading ‘move_group/ApplyPlanningSceneService’…
[move_group-4] Loading ‘move_group/ClearOctomapService’…
[move_group-4] Loading ‘move_group/MoveGroupCartesianPathService’…
[move_group-4] Loading ‘move_group/MoveGroupExecuteTrajectoryAction’…
[move_group-4] Loading ‘move_group/MoveGroupGetPlanningSceneService’…
[move_group-4] Loading ‘move_group/MoveGroupKinematicsService’…
[move_group-4] Loading ‘move_group/MoveGroupMoveAction’…
[move_group-4] Loading ‘move_group/MoveGroupPlanService’…
[move_group-4] Loading ‘move_group/MoveGroupQueryPlannersService’…
[move_group-4] Loading ‘move_group/MoveGroupStateValidationService’…
[move_group-4]
[move_group-4] You can start planning now!
[move_group-4]
[spawner-7] [INFO] [1778810670.573337744] [spawner_scaled_joint_trajectory_controller]: waiting for service /controller_manager/list_controllers to become available…
[ros2_control_node-5] [INFO] [1778810670.600023857] [controller_manager]: Loading controller ‘joint_state_broadcaster’
[spawner-8] [INFO] [1778810670.613003849] [spawner_joint_trajectory_controller]: waiting for service /controller_manager/list_controllers to become available…
[spawner-6] [INFO] [1778810670.667762014] [spawner_joint_state_broadcaster]: Loaded joint_state_broadcaster
[ros2_control_node-5] [INFO] [1778810670.668748655] [controller_manager]: Configuring controller ‘joint_state_broadcaster’
[ros2_control_node-5] [INFO] [1778810670.668828882] [joint_state_broadcaster]: ‘joints’ or ‘interfaces’ parameter is empty. All available state interfaces will be published
[rviz2-1] [INFO] [1778810670.953646732] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-1] [INFO] [1778810670.953839684] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
[spawner-6] [INFO] [1778810670.956299404] [spawner_joint_state_broadcaster]: Configured and activated joint_state_broadcaster
[ros2_control_node-5] [INFO] [1778810670.957265836] [controller_manager]: Loading controller ‘scaled_joint_trajectory_controller’
[ros2_control_node-5] [WARN] [1778810670.969861131] [scaled_joint_trajectory_controller]: [Deprecated]: “allow_nonzero_velocity_at_trajectory_end” is set to true. The default behavior will change to false.
[rviz2-1] [INFO] [1778810670.971832695] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-1] Warning: class_loader.impl: SEVERE WARNING!!! A namespace collision has occurred with plugin factory for class rviz_default_plugins::displays::InteractiveMarkerDisplay. New factory will OVERWRITE existing one. This situation occurs when libraries containing plugins are directly linked against an executable (the one running right now generating this message). Please separate plugins out into their own library or just don’t link against the library and use either class_loader::ClassLoader/MultiLibraryClassLoader to open.
[rviz2-1] at line 253 in /opt/ros/humble/include/class_loader/class_loader/class_loader_core.hpp
[ros2_control_node-5] [INFO] [1778810671.053231800] [controller_manager]: Loading controller ‘joint_trajectory_controller’
[spawner-7] [INFO] [1778810671.055195587] [spawner_scaled_joint_trajectory_controller]: Loaded scaled_joint_trajectory_controller
[ros2_control_node-5] [WARN] [1778810671.065443566] [joint_trajectory_controller]: [Deprecated]: “allow_nonzero_velocity_at_trajectory_end” is set to true. The default behavior will change to false.
[INFO] [spawner-6]: process has finished cleanly [pid 21052]
[ros2_control_node-5] [INFO] [1778810671.155496378] [controller_manager]: Configuring controller ‘scaled_joint_trajectory_controller’
[ros2_control_node-5] [INFO] [1778810671.155680636] [scaled_joint_trajectory_controller]: No specific joint names are used for command interfaces. Using ‘joints’ parameter.
[ros2_control_node-5] [INFO] [1778810671.155711440] [scaled_joint_trajectory_controller]: Command interfaces are [position] and state interfaces are [position velocity].
[ros2_control_node-5] [INFO] [1778810671.155728404] [scaled_joint_trajectory_controller]: Using ‘splines’ interpolation method.
[spawner-8] [INFO] [1778810671.156141179] [spawner_joint_trajectory_controller]: Loaded joint_trajectory_controller
[ros2_control_node-5] [INFO] [1778810671.156505613] [scaled_joint_trajectory_controller]: Controller state will be published at 50.00 Hz.
[ros2_control_node-5] [INFO] [1778810671.157974424] [scaled_joint_trajectory_controller]: Action status changes will be monitored at 20.00 Hz.
[ros2_control_node-5] [INFO] [1778810671.248555281] [controller_manager]: Configuring controller ‘joint_trajectory_controller’
[ros2_control_node-5] [INFO] [1778810671.248744607] [joint_trajectory_controller]: No specific joint names are used for command interfaces. Using ‘joints’ parameter.
[ros2_control_node-5] [INFO] [1778810671.248767934] [joint_trajectory_controller]: Command interfaces are [position] and state interfaces are [position velocity].
[ros2_control_node-5] [INFO] [1778810671.248782529] [joint_trajectory_controller]: Using ‘splines’ interpolation method.
[ros2_control_node-5] [INFO] [1778810671.249592835] [joint_trajectory_controller]: Controller state will be published at 50.00 Hz.
[ros2_control_node-5] [INFO] [1778810671.250766488] [joint_trajectory_controller]: Action status changes will be monitored at 20.00 Hz.
[cumotion_planner_node-9] kinematics_fused_cu not found, JIT compiling…
[spawner-7] [INFO] [1778810671.530171991] [spawner_scaled_joint_trajectory_controller]: Configured and activated scaled_joint_trajectory_controller
[ros2_control_node-5] [ERROR] [1778810671.626519783] [controller_manager]: Resource conflict for controller ‘joint_trajectory_controller’. Command interface ‘shoulder_pan_joint/position’ is already claimed.
[ros2_control_node-5] [ERROR] [1778810671.626646744] [controller_manager]: Could not activate controller : ‘joint_trajectory_controller’
[INFO] [spawner-7]: process has finished cleanly [pid 21054]
[spawner-8] [ERROR] [1778810671.722081645] [spawner_joint_trajectory_controller]: Failed to activate controller : joint_trajectory_controller
[cumotion_planner_node-9] /usr/local/lib/python3.10/dist-packages/torch/utils/cpp_extension.py:1965: UserWarning: TORCH_CUDA_ARCH_LIST is not set, all archs for visible cards are included for compilation.
[cumotion_planner_node-9] If this is not desired, please set os.environ[‘TORCH_CUDA_ARCH_LIST’].
[cumotion_planner_node-9] warnings.warn(
[ERROR] [spawner-8]: process has died [pid 21056, exit code 1, cmd ‘/opt/ros/humble/lib/controller_manager/spawner joint_trajectory_controller -c /controller_manager --ros-args’].
[cumotion_planner_node-9] geom_cu binary not found, jit compiling…
[cumotion_planner_node-9] tensor_step_cu not found, jit compiling…
[cumotion_planner_node-9] lbfgs_step_cu not found, JIT compiling…
[cumotion_planner_node-9] line_search_cu not found, JIT compiling…
[cumotion_planner_node-9] [INFO] [1778810673.116165758] [cumotion_planner]: Loading grid position and dims from grid_center_m and grid_size_m parameters.
[rviz2-1] [ERROR] [1778810674.070368799] [moveit_ros_visualization.motion_planning_frame]: Action server: /recognize_objects not available
[rviz2-1] [INFO] [1778810674.078503385] [moveit_ros_visualization.motion_planning_frame]: MoveGroup namespace changed: / → . Reloading params.
[rviz2-1] Error: Semantic description is not specified for the same robot as the URDF
[rviz2-1] at line 681 in ./src/model.cpp
[rviz2-1] [INFO] [1778810674.083354649] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0 seconds
[rviz2-1] [INFO] [1778810674.083379546] [moveit_robot_model.robot_model]: Loading robot model ‘ur10e’…
[rviz2-1] [INFO] [1778810674.083385045] [moveit_robot_model.robot_model]: No root/virtual joint specified in SRDF. Assuming fixed joint
[rviz2-1] [INFO] [1778810674.295084272] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0 seconds
[rviz2-1] [INFO] [1778810674.295107836] [moveit_robot_model.robot_model]: Loading robot model ‘ur10e’…
[rviz2-1] [INFO] [1778810674.295110710] [moveit_robot_model.robot_model]: No root/virtual joint specified in SRDF. Assuming fixed joint
[rviz2-1] [INFO] [1778810674.356484719] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
[rviz2-1] [INFO] [1778810674.357107228] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to ‘/monitored_planning_scene’
[rviz2-1] [INFO] [1778810674.358237032] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
[rviz2-1] [INFO] [1778810674.358995831] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to ‘/monitored_planning_scene’
[rviz2-1] [INFO] [1778810674.363677524] [interactive_marker_display_109771095687728]: Connected on namespace: /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic
[rviz2-1] [INFO] [1778810674.367013997] [moveit_ros_visualization.motion_planning_frame]: group ur_manipulator
[rviz2-1] [INFO] [1778810674.367035731] [moveit_ros_visualization.motion_planning_frame]: Constructing new MoveGroup connection for group ‘ur_manipulator’ in namespace ‘’
[rviz2-1] [INFO] [1778810674.374739013] [move_group_interface]: Ready to take commands for planning group ur_manipulator.
[rviz2-1] [INFO] [1778810674.388664409] [interactive_marker_display_109771095687728]: Sending request for interactive markers
[rviz2-1] [INFO] [1778810674.433351901] [interactive_marker_display_109771095687728]: Service response received for initialization
[cumotion_planner_node-9] [INFO] [1778810674.877852306] [cumotion_planner]: warming up cuMotion, wait until ready
[cumotion_planner_node-9] [INFO] [1778810684.192387815] [cumotion_planner]: cuMotion is ready for planning queries!
^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
[robot_state_publisher-2] [INFO] [1778810716.610686521] [rclcpp]: signal_handler(SIGINT/SIGTERM)
[rviz2-1] [INFO] [1778810716.610700822] [rclcpp]: signal_handler(SIGINT/SIGTERM)
[ros2_control_node-5] [INFO] [1778810716.610727260] [rclcpp]: signal_handler(SIGINT/SIGTERM)
[ros2_control_node-5] [INFO] [1778810716.610798051] [controller_manager]: Shutdown request received…
[ros2_control_node-5] [INFO] [1778810716.610876351] [controller_manager]: Shutting down all controllers in the controller manager.
[ros2_control_node-5] [INFO] [1778810716.610901152] [controller_manager]: Deactivating controller ‘joint_state_broadcaster’
[ros2_control_node-5] [INFO] [1778810716.610937441] [controller_manager]: Shutting down controller ‘joint_state_broadcaster’
[ros2_control_node-5] [INFO] [1778810716.610954589] [controller_manager]: Deactivating controller ‘scaled_joint_trajectory_controller’
[ros2_control_node-5] [INFO] [1778810716.610982039] [controller_manager]: Shutting down controller ‘scaled_joint_trajectory_controller’
[ros2_control_node-5] [INFO] [1778810716.610992645] [controller_manager]: Shutting down controller ‘joint_trajectory_controller’
[ros2_control_node-5] [INFO] [1778810716.611021267] [resource_manager]: ‘deactivate’ hardware ‘URFakeSystem’
[ros2_control_node-5] [INFO] [1778810716.611030624] [resource_manager]: Successful ‘deactivate’ of hardware ‘URFakeSystem’
[ros2_control_node-5] [INFO] [1778810716.611034342] [resource_manager]: ‘shutdown’ hardware ‘URFakeSystem’
[ros2_control_node-5] [INFO] [1778810716.611040348] [resource_manager]: Successful ‘shutdown’ of hardware ‘URFakeSystem’
[ros2_control_node-5] [INFO] [1778810716.611043283] [controller_manager]: Shutting down the controller manager.
[static_transform_publisher-3] [INFO] [1778810716.610737370] [rclcpp]: signal_handler(SIGINT/SIGTERM)
[move_group-4] [INFO] [1778810716.610741084] [rclcpp]: signal_handler(SIGINT/SIGTERM)
[cumotion_planner_node-9] [INFO] [1778810716.611360615] [cumotion_planner]: KeyboardInterrupt, shutting down.
[cumotion_planner_node-9] Failed to publish log message to rosout: publisher’s context is invalid, at ./src/rcl/publisher.c:389
[cumotion_planner_node-9] Warp DeprecationWarning: The symbol warp.torch.device_from_torch will soon be removed from the public API. Use warp.device_from_torch instead.
[move_group-4] [INFO] [1778810716.623493675] [moveit.ros_planning_interface.moveit_cpp]: Deleting MoveItCpp
[rviz2-1] [WARN] [1778810716.627877138] [interactive_marker_display_109771095687728]: Server not available while running, resetting
[INFO] [static_transform_publisher-3]: process has finished cleanly [pid 21046]
[INFO] [robot_state_publisher-2]: process has finished cleanly [pid 21044]
[rviz2-1]
[rviz2-1] >>> [rcutils|error_handling.c:108] rcutils_set_error_state()
[rviz2-1] This error state is being overwritten:
[rviz2-1]
[rviz2-1] ‘rcl node’s context is invalid, at ./src/rcl/node.c:428’
[rviz2-1]
[rviz2-1] with this new error message:
[rviz2-1]
[rviz2-1] ‘publisher’s context is invalid, at ./src/rcl/publisher.c:389’
[rviz2-1]
[rviz2-1] rcutils_reset_error() should be called after error handling to avoid this.
[rviz2-1] <<<
[rviz2-1] [INFO] [1778810716.723308797] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Stopping planning scene monitor
[rviz2-1] [INFO] [1778810716.726747621] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Stopping planning scene monitor
[INFO] [ros2_control_node-5]: process has finished cleanly [pid 21050]
^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT) again, ignoring…
[ERROR] [move_group-4]: process has died [pid 21048, exit code -2, cmd ‘/opt/ros/humble/lib/moveit_ros_move_group/move_group --ros-args --log-level info --ros-args --params-file /tmp/launch_params_b0hu0ve_’].
[move_group-4]
[ERROR] [cumotion_planner_node-9]: process has died [pid 21058, exit code -2, cmd ‘/opt/ros/humble/lib/isaac_ros_cumotion/cumotion_planner_node --ros-args -r __node:=cumotion_planner -r __ns:=/ --params-file /tmp/launch_params_6jnwknfm’].
[ERROR] [rviz2-1]: process has died [pid 21042, exit code -11, cmd ‘/opt/ros/humble/lib/rviz2/rviz2 -d /opt/ros/humble/share/isaac_ros_cumotion_examples/rviz/ur_moveit_config.rviz --ros-args -r _node:=rviz2 --params-file /tmp/launch_params_ivkrr7np --params-file /tmp/launch_params_gc1z4jzj --params-file /tmp/launch_params_mxswsny --params-file /tmp/launch_params_oj0vwue3 --params-file /tmp/launch_params_8tubes2b --params-file /tmp/launch_params__xf7s80l’].
Could you please clarify if your first issue (running isaac_ros_cumotion_moveit — isaac_ros_docs documentation ) has been resolved?
For your second question regarding running the CuMotion example with UR and Isaac Sim.
Based on the log you shared, the launch succeeded. Both MoveIt and cuMotion came up correctly.[move_group-4] You can start planning now!
[cumotion_planner_node-9] cuMotion is ready for planning queries!
However, this launch on its own won’t do anything meaningful without Isaac Sim running separately and publishing /isaac_joint_states.
Steps to actually run the demo end-to-end:
1. Open Isaac Sim (separate process, GUI).
2. Load the UR cuMotion sample USD scene from the cuMotion examples assets package.
The scene has a pre-wired OmniGraph that publishes to /isaac_joint_states and
subscribes to /isaac_joint_commands.
3. Press Play in Isaac Sim — without this the OmniGraph doesn't tick and the topics
stay silent.
4. In a separate terminal, source your ROS workspace and run:
5. In the RViz window that opens, use the MotionPlanning panel:
drag the orange interactive marker to a new pose, click Plan, then Execute.
The UR in Isaac Sim should move.
Verify Isaac Sim is correctly publishing before you try to plan:
ros2 topic hz /isaac_joint_states # should be ~60 Hz
ros2 topic hz /joint_states # should be ~100 Hz
ros2 topic echo /joint_states --once # should show real joint angles
If /isaac_joint_states is silent (“No new messages received”), that’s the real blocker. Isaac Sim isn’t running, isn’t playing, or its ROS 2 bridge extension isn’t enabled. Fix that before trying to plan.
As there haven’t been any recent updates on this discussion, we’ll be closing the thread to keep the forum organized.
If you continue to experience this issue or have new questions, please start a new topic and include a reference to this discussion for context. This will help our team and other community members assist you more effectively.
Thank you for your participation in the NVIDIA Isaac ROS community.
