Something happened, please contact support or try restarting the application and installer
C:\Users\linds\AppData\Local\NVIDIA Corporation\AI Workbench\logs dir to logs
CPU RYZEN 5 3600
32gb RAM
4070ti
Windows 11
winver 23h2 22631.3007
wsl status wsl2 Ubuntu 2204.3.49.0
wsl unregister and reinstall dont helped
Welcome to AI Workbench, Workbench depends on a specific wsl distro named NVIDIA-Workbench it is ubuntu 22.04 OS. In your case I recommend re-installing workbench, just rerun the installer. This should create the proper wsl distro. after the installer completes. Test by wsl -u workbench -d NVIDIA-Workbench in a PowerShell or cmd.exe window.
dont work(
main.log (4.9 KB)
I get the same error.
Upon checking the log, the error appears to be on Ubuntu’s repository side.
The installation program is referencing a distro that is not there.
In the log, the line downloadFile() https://cloud-images.ubuntu.com/wsl/jammy/current/ubuntu-jammy-wsl-amd64-wsl.rootfs.tar.gz, that url returns a 404 if you try it manually.
[2024-02-13 15:45:40.080] [info]  (tray)                               initTray
[2024-02-13 15:45:40.086] [info]  (main)                               NVWB_CLI_VERSION 0.13.14 WB_SVC_VERSION 0.18.7 CREDENTIAL_MANAGER_VERSION 1.1.1
[2024-02-13 15:45:40.088] [info]  (tab-registry)                       cleared project-tag-registry store
[2024-02-13 15:45:40.092] [info]  (window-context-registry)            cleared window-context-registry-store
[2024-02-13 15:45:40.098] [info]  (main)                               async() Start electron main
[2024-02-13 15:45:40.172] [info]  (menu)                               initMenu
[2024-02-13 15:45:40.176] [info]  (main)                               message with user scope
[2024-02-13 15:45:40.176] [info]  (createWindow-installer)
  createWindow(
    windowName: installer,
    windowIndex: ./installer/index.html,
    options {"width":952,"height":650},
[2024-02-13 15:45:40.179] [info]  (createWindow-installer)             resetToDefaults(windowState: [object Object])
[2024-02-13 15:45:40.180] [info]  (createWindow-installer)             windowWithinBounds()
[2024-02-13 15:45:40.180] [info]  (createWindow-installer)             resetToDefaults()
[2024-02-13 15:45:40.245] [info]  (new-window-events)                  event { preventDefault: '[function] preventDefault(){}' }
[2024-02-13 15:45:40.246] [info]  (new-window-events)                  data {
  setBounds: '[function] (e,...t)=>{e={...this.getBounds(),...e},s.call(this,e,...t)}',
  _events: {
    blur: '[function] t=>{e.emit("browser-window-blur",t,this)}',
    focus: '[function] t=>{e.emit("browser-window-focus",t,this)}',
    show: '[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?"visible":"hidden";this.webContents.emit("-window-visibility-change",t)}}',
    hide: '[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?"visible":"hidden";this.webContents.emit("-window-visibility-change",t)}}',
    minimize: '[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?"visible":"hidden";this.webContents.emit("-window-visibility-change",t)}}',
    maximize: '[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?"visible":"hidden";this.webContents.emit("-window-visibility-change",t)}}',
    restore: '[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?"visible":"hidden";this.webContents.emit("-window-visibility-change",t)}}'
  _eventsCount: 7
[2024-02-13 15:45:40.298] [info]  (channel-registry)                   registerIpcChannels() Register ipc channels
[2024-02-13 15:45:40.298] [info]  (open-workbench)                     open_window
[2024-02-13 15:45:40.299] [info]  (open-file-picker-channel)           open_file_picker
[2024-02-13 15:45:40.300] [info]  (project-tab-registry-channel)       project_tab_registry_channel
[2024-02-13 15:45:40.300] [info]  (open-file-picker-channel)           open-external-link
[2024-02-13 15:45:40.300] [info]  (open-file-picker-channel)           open_file
[2024-02-13 15:45:40.301] [info]  (open-folder-picker-channel)         open_folder
[2024-02-13 15:45:40.301] [info]  (renderer)                           electron-log
[2024-02-13 15:45:40.302] [info]  (open-in-context-channel)            open_project_in_context
[2024-02-13 15:45:40.886] [info]  (renderer)                           Installer App() Loading
[2024-02-13 15:45:40.914] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 15:45:40.915] [info]  (renderer)                           SERVICE: workbenchServiceInstalledCheck(), CHANNEL: [get_storage, service_install_check]
[2024-02-13 15:45:40.915] [info]  (get-app-storage)                    {
  _deserialize: '[function] e=>JSON.parse(e)',
  _serialize: '[function] e=>JSON.stringify(e,void 0,"\\t")',
  events: { _events: {}, _eventsCount: 0 },
  path: 'C:\\Users\\username\\AppData\\Local\\NVIDIA Corporation\\AI Workbench\\registries\\workbench-config.json'
} installer.workbenchServiceState
[2024-02-13 15:45:40.916] [info]  (get-app-storage)                    {
  firstLoad: true,
  isInstalled: false,
  remoteOnly: null,
  rebootFromWSL2: false,
  installationHasRunSuccessfully: false
[2024-02-13 15:45:40.917] [info]  (service-installed-check-channel)    ServiceInstalledCheck.handle()
[2024-02-13 15:45:40.918] [info]  (service-installed-check)            serviceInstalledCheck()
[2024-02-13 15:45:40.927] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 15:45:41.351] [error] (service-installed-check-channel)    Command failed: wsl -u workbench -d NVIDIA-Workbench -- ls /home/workbench/.nvwb/bin/
[2024-02-13 15:45:41.353] [info]  (renderer)                           Navigating to welcome-screen-route, /transition
[2024-02-13 15:45:48.882] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 15:45:48.883] [info]  (renderer)                           SERVICE: internetAvailableCheck()
[2024-02-13 15:45:48.885] [info]  (check-host-channel)                 check_connection
[2024-02-13 15:45:48.886] [info]  (check-connection)                   checkConnection()
[2024-02-13 15:45:48.907] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 15:45:49.392] [info]  (check-connection)                   checkInternet() 200
[2024-02-13 15:45:49.393] [info]  (renderer)                           SERVICE: internetAvailableCheck(), CHANNEL: check_connection
[2024-02-13 15:45:49.394] [info]  (introspect-os-channel)              introspect_os
[2024-02-13 15:45:49.395] [info]  (introspect-os)                      introspectOS()
[2024-02-13 15:45:49.395] [info]  (introspect-os)                      checkWindowsRelease [ '10', '0', '22631' ]
[2024-02-13 15:45:49.396] [info]  (introspect-os)                      isWinSupported true
[2024-02-13 15:45:49.692] [info]  (introspect-os)                      checkWslState wsl -v W S L   v e r s i o n :   2 . 0 . 9 . 0
 K e r n e l   v e r s i o n :   5 . 1 5 . 1 3 3 . 1 - 1
 W S L g   v e r s i o n :   1 . 0 . 5 9
 M S R D C   v e r s i o n :   1 . 2 . 4 6 7 7
 D i r e c t 3 D   v e r s i o n :   1 . 6 1 1 . 1 - 8 1 5 2 8 5 1 1
 D X C o r e   v e r s i o n :   1 0 . 0 . 2 5 1 3 1 . 1 0 0 2 - 2 2 0 5 3 1 - 1 7 0 0 . r s - o n e c o r e - b a s e 2 - h y p
 W i n d o w s   v e r s i o n :   1 0 . 0 . 2 2 6 3 1 . 3 0 8 5
[2024-02-13 15:45:49.693] [info]  (check-if-exists)                    C:\Users\username\.wslconfig
[2024-02-13 15:45:49.694] [error] (check-if-exists)                    checkIfExists ENOENT: no such file or directory, access 'C:\Users\username\.wslconfig'
[2024-02-13 15:45:49.694] [info]  (introspect-os)                      checkWslState C:\Users\username\.wslconfig exists: false
[2024-02-13 15:45:49.700] [info]  (introspect-os)                      windowsWslCheck()     N A M E             S T A T E                       V E R S I O N
 *   U b u n t u         S t o p p e d                   2
[2024-02-13 15:45:49.700] [info]  (introspect-os)                      wsl -l -v NAMESTATEVERSIONUbuntuStopped2 9 29
[2024-02-13 15:45:49.981] [error] (introspect-os)                      windowsWslCheck(): error hostCheckCommand Command failed: wsl -d NVIDIA-Workbench -- /home/workbench ls
[2024-02-13 15:45:49.981] [error] (introspect-os)                      windowsWslCheck stderr WSL:DISTRO:NOT:INSTALLED
[2024-02-13 15:45:49.982] [info]  (introspect-os-channel)              { osHost: 'win32', osSupported: true, wslInstalled: true, error: null }
[2024-02-13 15:45:49.982] [info]  (renderer)                           SERVICE: hostCheck(), CHANNEL: introspect_os {"osHost":"win32","osSupported":true,"wslInstalled":true,"error":null}
[2024-02-13 15:45:49.987] [info]  (configure-distro-channel)           configureDistro.handle()
[2024-02-13 15:45:49.987] [info]  (configure-distro)                   ConfigureDistro.configureDistro(BrowserWindow)
[2024-02-13 15:45:49.988] [info]  (configure-distro)                   checkDistroInstalled()
[2024-02-13 15:45:49.998] [info]  (renderer)                           Navigating to distro-progress, /transition
[2024-02-13 15:45:50.258] [info]  (configure-distro)                   checkDistroInstalled(): isDistroMatch => false
[2024-02-13 15:45:50.259] [info]  (check-if-exists)                    C:\ProgramData\NVIDIA Corporation
[2024-02-13 15:45:50.260] [info]  (download-util)                      downloadFile() https://cloud-images.ubuntu.com/wsl/jammy/current/ubuntu-jammy-wsl-amd64-wsl.rootfs.tar.gz C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz distro_download_progress
[2024-02-13 15:45:50.261] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STARTED
[2024-02-13 15:45:50.725] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: FAILED
[2024-02-13 15:45:50.726] [error] (download-util)                      Something happened Response status was 404
[2024-02-13 15:45:50.726] [error] (download-util)                      Error: Response status was 404
    at ClientRequest.<anonymous> (C:\Program Files\NVIDIA AI Workbench\resources\app.asar\dist\main\main.js:8:170377)
    at Object.onceWrapper (node:events:629:26)
    at ClientRequest.emit (node:events:514:28)
    at HTTPParser.parserOnIncomingClient (node:_http_client:700:27)
    at HTTPParser.parserOnHeadersComplete (node:_http_common:119:17)
    at TLSSocket.socketOnData (node:_http_client:541:22)
    at TLSSocket.emit (node:events:514:28)
    at addChunk (node:internal/streams/readable:324:12)
    at readableAddChunk (node:internal/streams/readable:297:9)
    at TLSSocket.push (node:internal/streams/readable:234:10)
[2024-02-13 15:45:50.727] [info]  (configure-distro)                   downloadTarResponse {
  isCompleted: false,
  error: { isCompleted: false, error: 'Response status was 404' }
[2024-02-13 15:45:50.727] [info]  (configure-distro)                   isDistroInstalled(): error downloadTarResponse.error { isCompleted: false, error: 'Response status was 404' }
[2024-02-13 15:45:50.727] [error] (configure-distro-channel)           Unknown Error
[2024-02-13 15:45:50.728] [info]  (renderer)                           SERVICE: configureDistro(), CHANNEL: configure_distro
[2024-02-13 15:45:50.729] [info]  (renderer)                           Navigating to app-error, /distro-progress
[2024-02-13 15:45:51.734] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: RETRY
[2024-02-13 15:45:51.735] [info]  (download-util)
				RetryAttempt: 1/5,
				StartsOn: 5 secs,
				Reason: timeout
[2024-02-13 15:45:56.743] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STARTED
[2024-02-13 15:45:57.156] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: FAILED
[2024-02-13 15:45:57.157] [error] (download-util)                      Something happened Response status was 404
[2024-02-13 15:45:57.254] [info]  (renderer)                           SERVICE: close(), CHANNEL: close
[2024-02-13 15:45:57.257] [info]  (close-window-channel)               closeWindow.handle()
[2024-02-13 15:45:57.257] [info]  (close-window)                       close()
[2024-02-13 15:45:57.258] [info]  (close-window)                       close function called 1 {}
[2024-02-13 15:45:57.258] [info]  (tab-registry)                       projectTabs cleanupWindowTabRegistry []
[2024-02-13 15:45:57.259] [info]  (createWindow-installer)             saveState()
[2024-02-13 15:45:57.259] [info]  (createWindow-installer)             getCurrentPosition()
[2024-02-13 15:45:57.263] [info]  (download-util)                      Download closeCallback() triggered by close event C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz
[2024-02-13 15:45:57.264] [info]  (close-window)                       cleanupWindowTabRegistry() response { isCompleted: true }
[2024-02-13 15:45:57.265] [info]  (cleanup)                            windowCleanup 1
[2024-02-13 15:45:57.265] [info]  (window-context-registry)            getContextReference() 1
[2024-02-13 15:45:57.303] [info]  (app-quit)                           app.on(window-all-closed) Windows closed safe to quit application
[2024-02-13 15:45:57.307] [info]  (close-window-channel)               { success: true }
[2024-02-13 15:45:57.309] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STOPPED
[2024-02-13 16:23:19.882] [info]  (tray)                               initTray
[2024-02-13 16:23:19.886] [info]  (main)                               NVWB_CLI_VERSION 0.13.14 WB_SVC_VERSION 0.18.7 CREDENTIAL_MANAGER_VERSION 1.1.1
[2024-02-13 16:23:19.887] [info]  (tab-registry)                       cleared project-tag-registry store
[2024-02-13 16:23:19.891] [info]  (window-context-registry)            cleared window-context-registry-store
[2024-02-13 16:23:19.895] [info]  (main)                               async() Start electron main
[2024-02-13 16:23:19.948] [info]  (menu)                               initMenu
[2024-02-13 16:23:19.949] [info]  (main)                               message with user scope
[2024-02-13 16:23:19.950] [info]  (createWindow-installer)
  createWindow(
[2024-02-13 16:23:19.954] [info]  (createWindow-installer)             resetToDefaults(windowState: [object Object])
[2024-02-13 16:23:19.954] [info]  (createWindow-installer)             windowWithinBounds()
[2024-02-13 16:23:19.996] [info]  (new-window-events)                  event { preventDefault: '[function] preventDefault(){}' }
[2024-02-13 16:23:19.997] [info]  (new-window-events)                  data {
  _events: {
  _eventsCount: 7
[2024-02-13 16:23:20.043] [info]  (channel-registry)                   registerIpcChannels() Register ipc channels
[2024-02-13 16:23:20.044] [info]  (open-workbench)                     open_window
[2024-02-13 16:23:20.044] [info]  (open-file-picker-channel)           open_file_picker
[2024-02-13 16:23:20.044] [info]  (project-tab-registry-channel)       project_tab_registry_channel
[2024-02-13 16:23:20.045] [info]  (open-file-picker-channel)           open-external-link
[2024-02-13 16:23:20.045] [info]  (open-file-picker-channel)           open_file
[2024-02-13 16:23:20.045] [info]  (open-folder-picker-channel)         open_folder
[2024-02-13 16:23:20.045] [info]  (renderer)                           electron-log
[2024-02-13 16:23:20.045] [info]  (open-in-context-channel)            open_project_in_context
[2024-02-13 16:23:20.630] [info]  (renderer)                           Installer App() Loading
[2024-02-13 16:23:20.656] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 16:23:20.657] [info]  (renderer)                           SERVICE: workbenchServiceInstalledCheck(), CHANNEL: [get_storage, service_install_check]
[2024-02-13 16:23:20.658] [info]  (get-app-storage)                    {
  firstLoad: true,
  isInstalled: false,
  remoteOnly: null,
[2024-02-13 16:23:20.659] [info]  (service-installed-check-channel)    ServiceInstalledCheck.handle()
[2024-02-13 16:23:20.659] [info]  (service-installed-check)            serviceInstalledCheck()
[2024-02-13 16:23:20.683] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 16:23:21.381] [error] (service-installed-check-channel)    Command failed: wsl -u workbench -d NVIDIA-Workbench -- ls /home/workbench/.nvwb/bin/
[2024-02-13 16:23:21.383] [info]  (renderer)                           Navigating to welcome-screen-route, /transition
[2024-02-13 16:23:24.484] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 16:23:24.485] [info]  (renderer)                           SERVICE: internetAvailableCheck()
[2024-02-13 16:23:24.487] [info]  (check-host-channel)                 check_connection
[2024-02-13 16:23:24.487] [info]  (check-connection)                   checkConnection()
[2024-02-13 16:23:24.504] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 16:23:25.559] [info]  (check-connection)                   checkInternet() 200
[2024-02-13 16:23:25.560] [info]  (renderer)                           SERVICE: internetAvailableCheck(), CHANNEL: check_connection
[2024-02-13 16:23:25.561] [info]  (introspect-os-channel)              introspect_os
[2024-02-13 16:23:25.562] [info]  (introspect-os)                      introspectOS()
[2024-02-13 16:23:25.562] [info]  (introspect-os)                      checkWindowsRelease [ '10', '0', '22631' ]
[2024-02-13 16:23:25.562] [info]  (introspect-os)                      isWinSupported true
[2024-02-13 16:23:26.070] [info]  (introspect-os)                      checkWslState wsl -v W S L   v e r s i o n :   2 . 0 . 9 . 0
[2024-02-13 16:23:26.071] [info]  (check-if-exists)                    C:\Users\username\.wslconfig
[2024-02-13 16:23:26.072] [error] (check-if-exists)                    checkIfExists ENOENT: no such file or directory, access 'C:\Users\username\.wslconfig'
[2024-02-13 16:23:26.072] [info]  (introspect-os)                      checkWslState C:\Users\username\.wslconfig exists: false
[2024-02-13 16:23:26.123] [info]  (introspect-os)                      windowsWslCheck()     N A M E             S T A T E                       V E R S I O N
[2024-02-13 16:23:26.123] [info]  (introspect-os)                      wsl -l -v NAMESTATEVERSIONUbuntuStopped2 9 29
[2024-02-13 16:23:26.511] [error] (introspect-os)                      windowsWslCheck(): error hostCheckCommand Command failed: wsl -d NVIDIA-Workbench -- /home/workbench ls
[2024-02-13 16:23:26.512] [error] (introspect-os)                      windowsWslCheck stderr WSL:DISTRO:NOT:INSTALLED
[2024-02-13 16:23:26.512] [info]  (introspect-os-channel)              { osHost: 'win32', osSupported: true, wslInstalled: true, error: null }
[2024-02-13 16:23:26.513] [info]  (renderer)                           SERVICE: hostCheck(), CHANNEL: introspect_os {"osHost":"win32","osSupported":true,"wslInstalled":true,"error":null}
[2024-02-13 16:23:26.517] [info]  (configure-distro-channel)           configureDistro.handle()
[2024-02-13 16:23:26.517] [info]  (configure-distro)                   ConfigureDistro.configureDistro(BrowserWindow)
[2024-02-13 16:23:26.518] [info]  (configure-distro)                   checkDistroInstalled()
[2024-02-13 16:23:26.523] [info]  (renderer)                           Navigating to distro-progress, /transition
[2024-02-13 16:23:26.956] [info]  (configure-distro)                   checkDistroInstalled(): isDistroMatch => false
[2024-02-13 16:23:26.957] [info]  (check-if-exists)                    C:\ProgramData\NVIDIA Corporation
[2024-02-13 16:23:26.959] [info]  (download-util)                      downloadFile() https://cloud-images.ubuntu.com/wsl/jammy/current/ubuntu-jammy-wsl-amd64-wsl.rootfs.tar.gz C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz distro_download_progress
[2024-02-13 16:23:26.960] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STARTED
[2024-02-13 16:23:27.687] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: FAILED
[2024-02-13 16:23:27.688] [error] (download-util)                      Something happened Response status was 404
[2024-02-13 16:23:27.688] [error] (download-util)                      Error: Response status was 404
[2024-02-13 16:23:27.694] [info]  (configure-distro)                   downloadTarResponse {
  isCompleted: false,
[2024-02-13 16:23:27.694] [info]  (configure-distro)                   isDistroInstalled(): error downloadTarResponse.error { isCompleted: false, error: 'Response status was 404' }
[2024-02-13 16:23:27.695] [error] (configure-distro-channel)           Unknown Error
[2024-02-13 16:23:27.696] [info]  (renderer)                           SERVICE: configureDistro(), CHANNEL: configure_distro
[2024-02-13 16:23:27.696] [info]  (renderer)                           Navigating to app-error, /distro-progress
[2024-02-13 16:23:28.692] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: RETRY
				RetryAttempt: 1/5,
				StartsOn: 5 secs,
				Reason: timeout
[2024-02-13 16:23:33.695] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STARTED
[2024-02-13 16:23:34.101] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: FAILED
[2024-02-13 16:23:34.102] [error] (download-util)                      Something happened Response status was 404
[2024-02-13 16:23:35.107] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: RETRY
[2024-02-13 16:23:35.108] [info]  (download-util)
				RetryAttempt: 1/5,
				StartsOn: 5 secs,
				Reason: timeout
[2024-02-13 16:23:38.288] [info]  (renderer)                           SERVICE: close(), CHANNEL: close
[2024-02-13 16:23:38.290] [info]  (close-window-channel)               closeWindow.handle()
[2024-02-13 16:23:38.291] [info]  (close-window)                       close()
[2024-02-13 16:23:38.292] [info]  (close-window)                       close function called 1 {}
[2024-02-13 16:23:38.293] [info]  (tab-registry)                       projectTabs cleanupWindowTabRegistry []
[2024-02-13 16:23:38.293] [info]  (createWindow-installer)             saveState()
[2024-02-13 16:23:38.293] [info]  (createWindow-installer)             getCurrentPosition()
[2024-02-13 16:23:38.297] [info]  (download-util)                      Download closeCallback() triggered by close event C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz
[2024-02-13 16:23:38.297] [info]  (close-window)                       cleanupWindowTabRegistry() response { isCompleted: true }
[2024-02-13 16:23:38.298] [info]  (cleanup)                            windowCleanup 1
[2024-02-13 16:23:38.298] [info]  (window-context-registry)            getContextReference() 1
[2024-02-13 16:23:38.312] [info]  (app-quit)                           app.on(window-all-closed) Windows closed safe to quit application
[2024-02-13 16:23:38.313] [info]  (close-window-channel)               { success: true }
[2024-02-13 16:23:38.315] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STOPPED
[2024-02-13 16:23:58.321] [info]  (tray)                               initTray
[2024-02-13 16:23:58.325] [info]  (main)                               NVWB_CLI_VERSION 0.13.14 WB_SVC_VERSION 0.18.7 CREDENTIAL_MANAGER_VERSION 1.1.1
[2024-02-13 16:23:58.326] [info]  (tab-registry)                       cleared project-tag-registry store
[2024-02-13 16:23:58.330] [info]  (window-context-registry)            cleared window-context-registry-store
[2024-02-13 16:23:58.336] [info]  (main)                               async() Start electron main
[2024-02-13 16:23:58.382] [info]  (menu)                               initMenu
[2024-02-13 16:23:58.383] [info]  (main)                               message with user scope
[2024-02-13 16:23:58.384] [info]  (createWindow-installer)
  createWindow(
[2024-02-13 16:23:58.386] [info]  (createWindow-installer)             resetToDefaults(windowState: [object Object])
[2024-02-13 16:23:58.386] [info]  (createWindow-installer)             windowWithinBounds()
[2024-02-13 16:23:58.433] [info]  (new-window-events)                  event { preventDefault: '[function] preventDefault(){}' }
[2024-02-13 16:23:58.434] [info]  (new-window-events)                  data {
  _events: {
  _eventsCount: 7
[2024-02-13 16:23:58.488] [info]  (channel-registry)                   registerIpcChannels() Register ipc channels
[2024-02-13 16:23:58.489] [info]  (open-workbench)                     open_window
[2024-02-13 16:23:58.489] [info]  (open-file-picker-channel)           open_file_picker
[2024-02-13 16:23:58.490] [info]  (project-tab-registry-channel)       project_tab_registry_channel
[2024-02-13 16:23:58.490] [info]  (open-file-picker-channel)           open-external-link
[2024-02-13 16:23:58.491] [info]  (open-file-picker-channel)           open_file
[2024-02-13 16:23:58.491] [info]  (open-folder-picker-channel)         open_folder
[2024-02-13 16:23:58.491] [info]  (renderer)                           electron-log
[2024-02-13 16:23:58.492] [info]  (open-in-context-channel)            open_project_in_context
[2024-02-13 16:23:59.093] [info]  (renderer)                           Installer App() Loading
[2024-02-13 16:23:59.118] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 16:23:59.120] [info]  (renderer)                           SERVICE: workbenchServiceInstalledCheck(), CHANNEL: [get_storage, service_install_check]
[2024-02-13 16:23:59.120] [info]  (get-app-storage)                    {
[2024-02-13 16:23:59.121] [info]  (get-app-storage)                    {
  firstLoad: true,
  isInstalled: false,
  remoteOnly: null,
[2024-02-13 16:23:59.122] [info]  (service-installed-check-channel)    ServiceInstalledCheck.handle()
[2024-02-13 16:23:59.122] [info]  (service-installed-check)            serviceInstalledCheck()
[2024-02-13 16:23:59.129] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 16:23:59.378] [error] (service-installed-check-channel)    Command failed: wsl -u workbench -d NVIDIA-Workbench -- ls /home/workbench/.nvwb/bin/
[2024-02-13 16:23:59.380] [info]  (renderer)                           Navigating to welcome-screen-route, /transition
[2024-02-13 16:24:07.012] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 16:24:07.014] [info]  (renderer)                           SERVICE: internetAvailableCheck()
[2024-02-13 16:24:07.015] [info]  (check-host-channel)                 check_connection
[2024-02-13 16:24:07.015] [info]  (check-connection)                   checkConnection()
[2024-02-13 16:24:07.034] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 16:24:07.539] [info]  (check-connection)                   checkInternet() 200
[2024-02-13 16:24:07.541] [info]  (renderer)                           SERVICE: internetAvailableCheck(), CHANNEL: check_connection
[2024-02-13 16:24:07.543] [info]  (introspect-os-channel)              introspect_os
[2024-02-13 16:24:07.544] [info]  (introspect-os)                      introspectOS()
[2024-02-13 16:24:07.544] [info]  (introspect-os)                      checkWindowsRelease [ '10', '0', '22631' ]
[2024-02-13 16:24:07.544] [info]  (introspect-os)                      isWinSupported true
[2024-02-13 16:24:07.821] [info]  (introspect-os)                      checkWslState wsl -v W S L   v e r s i o n :   2 . 0 . 9 . 0
[2024-02-13 16:24:07.822] [info]  (check-if-exists)                    C:\Users\username\.wslconfig
[2024-02-13 16:24:07.823] [error] (check-if-exists)                    checkIfExists ENOENT: no such file or directory, access 'C:\Users\username\.wslconfig'
[2024-02-13 16:24:07.823] [info]  (introspect-os)                      checkWslState C:\Users\username\.wslconfig exists: false
[2024-02-13 16:24:07.832] [info]  (introspect-os)                      windowsWslCheck()     N A M E             S T A T E                       V E R S I O N
[2024-02-13 16:24:07.832] [info]  (introspect-os)                      wsl -l -v NAMESTATEVERSIONUbuntuStopped2 9 29
[2024-02-13 16:24:08.082] [error] (introspect-os)                      windowsWslCheck(): error hostCheckCommand Command failed: wsl -d NVIDIA-Workbench -- /home/workbench ls
[2024-02-13 16:24:08.083] [error] (introspect-os)                      windowsWslCheck stderr WSL:DISTRO:NOT:INSTALLED
[2024-02-13 16:24:08.083] [info]  (introspect-os-channel)              { osHost: 'win32', osSupported: true, wslInstalled: true, error: null }
[2024-02-13 16:24:08.084] [info]  (renderer)                           SERVICE: hostCheck(), CHANNEL: introspect_os {"osHost":"win32","osSupported":true,"wslInstalled":true,"error":null}
[2024-02-13 16:24:08.088] [info]  (configure-distro-channel)           configureDistro.handle()
[2024-02-13 16:24:08.088] [info]  (configure-distro)                   ConfigureDistro.configureDistro(BrowserWindow)
[2024-02-13 16:24:08.088] [info]  (configure-distro)                   checkDistroInstalled()
[2024-02-13 16:24:08.093] [info]  (renderer)                           Navigating to distro-progress, /transition
[2024-02-13 16:24:08.321] [info]  (configure-distro)                   checkDistroInstalled(): isDistroMatch => false
[2024-02-13 16:24:08.322] [info]  (check-if-exists)                    C:\ProgramData\NVIDIA Corporation
[2024-02-13 16:24:08.323] [info]  (download-util)                      downloadFile() https://cloud-images.ubuntu.com/wsl/jammy/current/ubuntu-jammy-wsl-amd64-wsl.rootfs.tar.gz C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz distro_download_progress
[2024-02-13 16:24:08.324] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STARTED
[2024-02-13 16:24:08.827] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: FAILED
[2024-02-13 16:24:08.828] [error] (download-util)                      Something happened Response status was 404
[2024-02-13 16:24:08.828] [error] (download-util)                      Error: Response status was 404
[2024-02-13 16:24:08.830] [info]  (configure-distro)                   downloadTarResponse {
  isCompleted: false,
[2024-02-13 16:24:08.831] [info]  (configure-distro)                   isDistroInstalled(): error downloadTarResponse.error { isCompleted: false, error: 'Response status was 404' }
[2024-02-13 16:24:08.831] [error] (configure-distro-channel)           Unknown Error
[2024-02-13 16:24:08.832] [info]  (renderer)                           SERVICE: configureDistro(), CHANNEL: configure_distro
[2024-02-13 16:24:08.832] [info]  (renderer)                           Navigating to app-error, /distro-progress
[2024-02-13 16:24:09.829] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: RETRY
[2024-02-13 16:24:09.830] [info]  (download-util)
				RetryAttempt: 1/5,
				StartsOn: 5 secs,
				Reason: timeout
[2024-02-13 16:24:12.979] [info]  (renderer)                           SERVICE: close(), CHANNEL: close
[2024-02-13 16:24:12.980] [info]  (close-window-channel)               closeWindow.handle()
[2024-02-13 16:24:12.981] [info]  (close-window)                       close()
[2024-02-13 16:24:12.981] [info]  (close-window)                       close function called 1 {}
[2024-02-13 16:24:12.981] [info]  (tab-registry)                       projectTabs cleanupWindowTabRegistry []
[2024-02-13 16:24:12.982] [info]  (createWindow-installer)             saveState()
[2024-02-13 16:24:12.982] [info]  (createWindow-installer)             getCurrentPosition()
[2024-02-13 16:24:12.985] [info]  (download-util)                      Download closeCallback() triggered by close event C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz
[2024-02-13 16:24:12.985] [info]  (close-window)                       cleanupWindowTabRegistry() response { isCompleted: true }
[2024-02-13 16:24:12.985] [info]  (cleanup)                            windowCleanup 1
[2024-02-13 16:24:12.986] [info]  (window-context-registry)            getContextReference() 1
[2024-02-13 16:24:13.003] [info]  (app-quit)                           app.on(window-all-closed) Windows closed safe to quit application
[2024-02-13 16:24:13.005] [info]  (close-window-channel)               { success: true }
[2024-02-13 16:24:13.007] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STOPPED
[2024-02-13 16:24:36.109] [info]  (tray)                               initTray
[2024-02-13 16:24:36.113] [info]  (main)                               NVWB_CLI_VERSION 0.13.14 WB_SVC_VERSION 0.18.7 CREDENTIAL_MANAGER_VERSION 1.1.1
[2024-02-13 16:24:36.114] [info]  (tab-registry)                       cleared project-tag-registry store
[2024-02-13 16:24:36.118] [info]  (window-context-registry)            cleared window-context-registry-store
[2024-02-13 16:24:36.124] [info]  (main)                               async() Start electron main
[2024-02-13 16:24:36.165] [info]  (menu)                               initMenu
[2024-02-13 16:24:36.166] [info]  (main)                               message with user scope
[2024-02-13 16:24:36.167] [info]  (createWindow-installer)
  createWindow(
[2024-02-13 16:24:36.170] [info]  (createWindow-installer)             resetToDefaults(windowState: [object Object])
[2024-02-13 16:24:36.170] [info]  (createWindow-installer)             windowWithinBounds()
[2024-02-13 16:24:36.213] [info]  (new-window-events)                  event { preventDefault: '[function] preventDefault(){}' }
[2024-02-13 16:24:36.214] [info]  (new-window-events)                  data {
  _events: {
  _eventsCount: 7
[2024-02-13 16:24:36.263] [info]  (channel-registry)                   registerIpcChannels() Register ipc channels
[2024-02-13 16:24:36.264] [info]  (open-workbench)                     open_window
[2024-02-13 16:24:36.264] [info]  (open-file-picker-channel)           open_file_picker
[2024-02-13 16:24:36.264] [info]  (project-tab-registry-channel)       project_tab_registry_channel
[2024-02-13 16:24:36.264] [info]  (open-file-picker-channel)           open-external-link
[2024-02-13 16:24:36.265] [info]  (open-file-picker-channel)           open_file
[2024-02-13 16:24:36.265] [info]  (open-folder-picker-channel)         open_folder
[2024-02-13 16:24:36.265] [info]  (renderer)                           electron-log
[2024-02-13 16:24:36.266] [info]  (open-in-context-channel)            open_project_in_context
[2024-02-13 16:24:36.856] [info]  (renderer)                           Installer App() Loading
[2024-02-13 16:24:36.885] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 16:24:36.886] [info]  (renderer)                           SERVICE: workbenchServiceInstalledCheck(), CHANNEL: [get_storage, service_install_check]
[2024-02-13 16:24:36.886] [info]  (get-app-storage)                    {
[2024-02-13 16:24:36.887] [info]  (get-app-storage)                    {
  firstLoad: true,
  isInstalled: false,
  remoteOnly: null,
[2024-02-13 16:24:36.888] [info]  (service-installed-check-channel)    ServiceInstalledCheck.handle()
[2024-02-13 16:24:36.888] [info]  (service-installed-check)            serviceInstalledCheck()
[2024-02-13 16:24:36.897] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 16:24:37.176] [error] (service-installed-check-channel)    Command failed: wsl -u workbench -d NVIDIA-Workbench -- ls /home/workbench/.nvwb/bin/
[2024-02-13 16:24:37.178] [info]  (renderer)                           Navigating to welcome-screen-route, /transition
[2024-02-13 16:24:39.715] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 16:24:39.716] [info]  (renderer)                           SERVICE: internetAvailableCheck()
[2024-02-13 16:24:39.718] [info]  (check-host-channel)                 check_connection
[2024-02-13 16:24:39.719] [info]  (check-connection)                   checkConnection()
[2024-02-13 16:24:39.740] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 16:24:41.146] [info]  (check-connection)                   checkInternet() 200
[2024-02-13 16:24:41.147] [info]  (renderer)                           SERVICE: internetAvailableCheck(), CHANNEL: check_connection
[2024-02-13 16:24:41.149] [info]  (introspect-os-channel)              introspect_os
[2024-02-13 16:24:41.149] [info]  (introspect-os)                      introspectOS()
[2024-02-13 16:24:41.149] [info]  (introspect-os)                      checkWindowsRelease [ '10', '0', '22631' ]
[2024-02-13 16:24:41.150] [info]  (introspect-os)                      isWinSupported true
[2024-02-13 16:24:41.413] [info]  (introspect-os)                      checkWslState wsl -v W S L   v e r s i o n :   2 . 0 . 9 . 0
[2024-02-13 16:24:41.414] [info]  (check-if-exists)                    C:\Users\username\.wslconfig
[2024-02-13 16:24:41.415] [error] (check-if-exists)                    checkIfExists ENOENT: no such file or directory, access 'C:\Users\username\.wslconfig'
[2024-02-13 16:24:41.415] [info]  (introspect-os)                      checkWslState C:\Users\username\.wslconfig exists: false
[2024-02-13 16:24:41.421] [info]  (introspect-os)                      windowsWslCheck()     N A M E             S T A T E                       V E R S I O N
[2024-02-13 16:24:41.421] [info]  (introspect-os)                      wsl -l -v NAMESTATEVERSIONUbuntuStopped2 9 29
[2024-02-13 16:24:41.665] [error] (introspect-os)                      windowsWslCheck(): error hostCheckCommand Command failed: wsl -d NVIDIA-Workbench -- /home/workbench ls
[2024-02-13 16:24:41.665] [error] (introspect-os)                      windowsWslCheck stderr WSL:DISTRO:NOT:INSTALLED
[2024-02-13 16:24:41.666] [info]  (introspect-os-channel)              { osHost: 'win32', osSupported: true, wslInstalled: true, error: null }
[2024-02-13 16:24:41.667] [info]  (renderer)                           SERVICE: hostCheck(), CHANNEL: introspect_os {"osHost":"win32","osSupported":true,"wslInstalled":true,"error":null}
[2024-02-13 16:24:41.671] [info]  (configure-distro-channel)           configureDistro.handle()
[2024-02-13 16:24:41.672] [info]  (configure-distro)                   ConfigureDistro.configureDistro(BrowserWindow)
[2024-02-13 16:24:41.672] [info]  (configure-distro)                   checkDistroInstalled()
[2024-02-13 16:24:41.684] [info]  (renderer)                           Navigating to distro-progress, /transition
[2024-02-13 16:24:41.935] [info]  (configure-distro)                   checkDistroInstalled(): isDistroMatch => false
[2024-02-13 16:24:41.936] [info]  (check-if-exists)                    C:\ProgramData\NVIDIA Corporation
[2024-02-13 16:24:41.936] [info]  (download-util)                      downloadFile() https://cloud-images.ubuntu.com/wsl/jammy/current/ubuntu-jammy-wsl-amd64-wsl.rootfs.tar.gz C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz distro_download_progress
[2024-02-13 16:24:41.938] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STARTED
[2024-02-13 16:24:42.932] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: FAILED
[2024-02-13 16:24:42.933] [error] (download-util)                      Something happened Response status was 404
[2024-02-13 16:24:42.933] [error] (download-util)                      Error: Response status was 404
[2024-02-13 16:24:42.938] [info]  (configure-distro)                   downloadTarResponse {
  isCompleted: false,
[2024-02-13 16:24:42.938] [info]  (configure-distro)                   isDistroInstalled(): error downloadTarResponse.error { isCompleted: false, error: 'Response status was 404' }
[2024-02-13 16:24:42.939] [error] (configure-distro-channel)           Unknown Error
[2024-02-13 16:24:42.940] [info]  (renderer)                           SERVICE: configureDistro(), CHANNEL: configure_distro
[2024-02-13 16:24:42.941] [info]  (renderer)                           Navigating to app-error, /distro-progress
[2024-02-13 16:24:43.942] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: RETRY
				RetryAttempt: 1/5,
				StartsOn: 5 secs,
				Reason: timeout
[2024-02-13 16:24:48.944] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STARTED
[2024-02-13 16:24:49.361] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: FAILED
[2024-02-13 16:24:49.362] [error] (download-util)                      Something happened Response status was 404
[2024-02-13 16:24:50.376] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: RETRY
				RetryAttempt: 1/5,
				StartsOn: 5 secs,
				Reason: timeout
[2024-02-13 16:24:55.380] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STARTED
[2024-02-13 16:24:55.807] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: FAILED
[2024-02-13 16:24:55.807] [error] (download-util)                      Something happened Response status was 404
[2024-02-13 16:24:56.813] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: RETRY
[2024-02-13 16:24:56.814] [info]  (download-util)
				RetryAttempt: 1/5,
				StartsOn: 5 secs,
				Reason: timeout
[2024-02-13 16:24:57.144] [info]  (renderer)                           SERVICE: close(), CHANNEL: close
[2024-02-13 16:24:57.145] [info]  (close-window-channel)               closeWindow.handle()
[2024-02-13 16:24:57.145] [info]  (close-window)                       close()
[2024-02-13 16:24:57.146] [info]  (close-window)                       close function called 1 {}
[2024-02-13 16:24:57.146] [info]  (tab-registry)                       projectTabs cleanupWindowTabRegistry []
[2024-02-13 16:24:57.147] [info]  (createWindow-installer)             saveState()
[2024-02-13 16:24:57.147] [info]  (createWindow-installer)             getCurrentPosition()
[2024-02-13 16:24:57.151] [info]  (download-util)                      Download closeCallback() triggered by close event C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz
[2024-02-13 16:24:57.152] [info]  (close-window)                       cleanupWindowTabRegistry() response { isCompleted: true }
[2024-02-13 16:24:57.153] [info]  (cleanup)                            windowCleanup 1
[2024-02-13 16:24:57.153] [info]  (window-context-registry)            getContextReference() 1
[2024-02-13 16:24:57.172] [info]  (app-quit)                           app.on(window-all-closed) Windows closed safe to quit application
[2024-02-13 16:24:57.174] [info]  (close-window-channel)               { success: true }
[2024-02-13 16:24:57.176] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STOPPED
[2024-02-13 16:27:25.440] [info]  (tray)                               initTray
[2024-02-13 16:27:25.445] [info]  (main)                               NVWB_CLI_VERSION 0.13.14 WB_SVC_VERSION 0.18.7 CREDENTIAL_MANAGER_VERSION 1.1.1
[2024-02-13 16:27:25.447] [info]  (tab-registry)                       cleared project-tag-registry store
[2024-02-13 16:27:25.452] [info]  (window-context-registry)            cleared window-context-registry-store
[2024-02-13 16:27:25.456] [info]  (main)                               async() Start electron main
[2024-02-13 16:27:25.497] [info]  (menu)                               initMenu
[2024-02-13 16:27:25.499] [info]  (main)                               message with user scope
[2024-02-13 16:27:25.500] [info]  (createWindow-installer)
  createWindow(
[2024-02-13 16:27:25.504] [info]  (createWindow-installer)             resetToDefaults(windowState: [object Object])
[2024-02-13 16:27:25.504] [info]  (createWindow-installer)             windowWithinBounds()
[2024-02-13 16:27:25.545] [info]  (new-window-events)                  event { preventDefault: '[function] preventDefault(){}' }
[2024-02-13 16:27:25.545] [info]  (new-window-events)                  data {
  _events: {
  _eventsCount: 7
[2024-02-13 16:27:25.595] [info]  (channel-registry)                   registerIpcChannels() Register ipc channels
[2024-02-13 16:27:25.596] [info]  (open-workbench)                     open_window
[2024-02-13 16:27:25.596] [info]  (open-file-picker-channel)           open_file_picker
[2024-02-13 16:27:25.596] [info]  (project-tab-registry-channel)       project_tab_registry_channel
[2024-02-13 16:27:25.597] [info]  (open-file-picker-channel)           open-external-link
[2024-02-13 16:27:25.597] [info]  (open-file-picker-channel)           open_file
[2024-02-13 16:27:25.597] [info]  (open-folder-picker-channel)         open_folder
[2024-02-13 16:27:25.598] [info]  (renderer)                           electron-log
[2024-02-13 16:27:25.598] [info]  (open-in-context-channel)            open_project_in_context
[2024-02-13 16:27:26.177] [info]  (renderer)                           Installer App() Loading
[2024-02-13 16:27:26.204] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 16:27:26.206] [info]  (renderer)                           SERVICE: workbenchServiceInstalledCheck(), CHANNEL: [get_storage, service_install_check]
[2024-02-13 16:27:26.206] [info]  (get-app-storage)                    {
[2024-02-13 16:27:26.207] [info]  (get-app-storage)                    {
  firstLoad: true,
  isInstalled: false,
  remoteOnly: null,
[2024-02-13 16:27:26.208] [info]  (service-installed-check-channel)    ServiceInstalledCheck.handle()
[2024-02-13 16:27:26.209] [info]  (service-installed-check)            serviceInstalledCheck()
[2024-02-13 16:27:26.215] [info]  (renderer)                           Navigating to transition, /
[2024-02-13 16:27:26.670] [error] (service-installed-check-channel)    Command failed: wsl -u workbench -d NVIDIA-Workbench -- ls /home/workbench/.nvwb/bin/
[2024-02-13 16:27:26.671] [info]  (renderer)                           Navigating to welcome-screen-route, /transition
[2024-02-13 16:27:29.640] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 16:27:29.644] [info]  (renderer)                           SERVICE: internetAvailableCheck()
[2024-02-13 16:27:29.647] [info]  (check-host-channel)                 check_connection
[2024-02-13 16:27:29.648] [info]  (check-connection)                   checkConnection()
[2024-02-13 16:27:29.666] [info]  (renderer)                           Navigating to transition, /welcome-screen-route
[2024-02-13 16:27:32.288] [info]  (check-connection)                   checkInternet() 200
[2024-02-13 16:27:32.289] [info]  (renderer)                           SERVICE: internetAvailableCheck(), CHANNEL: check_connection
[2024-02-13 16:27:32.291] [info]  (introspect-os-channel)              introspect_os
[2024-02-13 16:27:32.291] [info]  (introspect-os)                      introspectOS()
[2024-02-13 16:27:32.291] [info]  (introspect-os)                      checkWindowsRelease [ '10', '0', '22631' ]
[2024-02-13 16:27:32.292] [info]  (introspect-os)                      isWinSupported true
[2024-02-13 16:27:32.605] [info]  (introspect-os)                      checkWslState wsl -v W S L   v e r s i o n :   2 . 0 . 9 . 0
[2024-02-13 16:27:32.606] [info]  (check-if-exists)                    C:\Users\username\.wslconfig
[2024-02-13 16:27:32.607] [error] (check-if-exists)                    checkIfExists ENOENT: no such file or directory, access 'C:\Users\username\.wslconfig'
[2024-02-13 16:27:32.607] [info]  (introspect-os)                      checkWslState C:\Users\username\.wslconfig exists: false
[2024-02-13 16:27:32.613] [info]  (introspect-os)                      windowsWslCheck()     N A M E             S T A T E                       V E R S I O N
[2024-02-13 16:27:32.614] [info]  (introspect-os)                      wsl -l -v NAMESTATEVERSIONUbuntuStopped2 9 29
[2024-02-13 16:27:32.887] [error] (introspect-os)                      windowsWslCheck(): error hostCheckCommand Command failed: wsl -d NVIDIA-Workbench -- /home/workbench ls
[2024-02-13 16:27:32.888] [error] (introspect-os)                      windowsWslCheck stderr WSL:DISTRO:NOT:INSTALLED
[2024-02-13 16:27:32.888] [info]  (introspect-os-channel)              { osHost: 'win32', osSupported: true, wslInstalled: true, error: null }
[2024-02-13 16:27:32.889] [info]  (renderer)                           SERVICE: hostCheck(), CHANNEL: introspect_os {"osHost":"win32","osSupported":true,"wslInstalled":true,"error":null}
[2024-02-13 16:27:32.893] [info]  (configure-distro-channel)           configureDistro.handle()
[2024-02-13 16:27:32.894] [info]  (configure-distro)                   ConfigureDistro.configureDistro(BrowserWindow)
[2024-02-13 16:27:32.894] [info]  (configure-distro)                   checkDistroInstalled()
[2024-02-13 16:27:32.899] [info]  (renderer)                           Navigating to distro-progress, /transition
[2024-02-13 16:27:33.179] [info]  (configure-distro)                   checkDistroInstalled(): isDistroMatch => false
[2024-02-13 16:27:33.179] [info]  (check-if-exists)                    C:\ProgramData\NVIDIA Corporation
[2024-02-13 16:27:33.180] [info]  (download-util)                      downloadFile() https://cloud-images.ubuntu.com/wsl/jammy/current/ubuntu-jammy-wsl-amd64-wsl.rootfs.tar.gz C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz distro_download_progress
[2024-02-13 16:27:33.181] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STARTED
[2024-02-13 16:27:33.912] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: FAILED
[2024-02-13 16:27:33.912] [error] (download-util)                      Something happened Response status was 404
[2024-02-13 16:27:33.913] [error] (download-util)                      Error: Response status was 404
[2024-02-13 16:27:33.917] [info]  (configure-distro)                   downloadTarResponse {
  isCompleted: false,
[2024-02-13 16:27:33.917] [info]  (configure-distro)                   isDistroInstalled(): error downloadTarResponse.error { isCompleted: false, error: 'Response status was 404' }
[2024-02-13 16:27:33.918] [error] (configure-distro-channel)           Unknown Error
[2024-02-13 16:27:33.918] [info]  (renderer)                           SERVICE: configureDistro(), CHANNEL: configure_distro
[2024-02-13 16:27:33.919] [info]  (renderer)                           Navigating to app-error, /distro-progress
[2024-02-13 16:27:34.914] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: RETRY
				RetryAttempt: 1/5,
				StartsOn: 5 secs,
				Reason: timeout
[2024-02-13 16:27:38.126] [info]  (renderer)                           SERVICE: close(), CHANNEL: close
[2024-02-13 16:27:38.127] [info]  (close-window-channel)               closeWindow.handle()
[2024-02-13 16:27:38.128] [info]  (close-window)                       close()
[2024-02-13 16:27:38.129] [info]  (close-window)                       close function called 1 {}
[2024-02-13 16:27:38.130] [info]  (tab-registry)                       projectTabs cleanupWindowTabRegistry []
[2024-02-13 16:27:38.131] [info]  (createWindow-installer)             saveState()
[2024-02-13 16:27:38.132] [info]  (createWindow-installer)             getCurrentPosition()
[2024-02-13 16:27:38.136] [info]  (download-util)                      Download closeCallback() triggered by close event C:\Users\username\AppData\Local\Temp\ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz
[2024-02-13 16:27:38.137] [info]  (close-window)                       cleanupWindowTabRegistry() response { isCompleted: true }
[2024-02-13 16:27:38.138] [info]  (cleanup)                            windowCleanup 1
[2024-02-13 16:27:38.138] [info]  (window-context-registry)            getContextReference() 1
[2024-02-13 16:27:38.162] [info]  (app-quit)                           app.on(window-all-closed) Windows closed safe to quit application
[2024-02-13 16:27:38.163] [info]  (close-window-channel)               { success: true }
[2024-02-13 16:27:38.164] [info]  (download-util)                      \ubuntu-jammy-wsl-arm64-wsl.rootfs.tar.gz: STOPPED
Hi Carlos
Thanks for posting the log and making this observation.
We will look into it and get back to you.
Tyler
Hello.
I am running into this issue also with the
returning 404
