VC2005 compiler shows the error message ~
1>Edge_Detection.cu
1>c:\program files\nvidia corporation\nvidia cuda sdk\projects\00_edge_detection_66_2\Edge_Detection_kernel.cu(109): error: expression must have (pointer-to-) function type
1>c:\program files\nvidia corporation\nvidia cuda sdk\projects\00_edge_detection_66_2\Edge_Detection_kernel.cu(116): error: expression must have (pointer-to-) function type
1>c:\program files\nvidia corporation\nvidia cuda sdk\projects\00_edge_detection_66_2\Edge_Detection_kernel.cu(126): error: expression must have (pointer-to-) function type
1>5 errors detected in the compilation of “C:\DOCUME~1\Eric\LOCALS~1\Temp/tmpxft_00000934_00000000-6_Edge_Detection.cpp1.ii”.
I have no idea about this problem …
It seems to be illegal that I copy the data from global memory to shared memory (in Edge_Detection_kernel.cu)…
But … compiler didn’t pass this …
Does anyone know how to solve this ~ ?
I write the note to explain where the error is …
============= Edge_Detection.cu ======================
#include “Edge_Detection_kernel.cu”
#include <cutil.h>
#include “Edge.h”
//*** Image Data
unsigned char *Dev_img_data = NULL ;
float *Dev_Result_data = NULL ;
int size_img_data ;
int size_result_img_data ;
void Copy_IMG_to_cu(unsigned char *img_data , float *Result_img , int width , int height)
unsigned int total_timer ; float total_elapsedTimeInMs ;
CUT_SAFE_CALL( cutCreateTimer( &total_timer ) );
CUT_SAFE_CALL( cutStartTimer( total_timer));
//Create Image Memory (global memory)
size_img_data = widthheight3sizeof(unsigned char) ;
size_result_img_data = widthheight*sizeof(float) ;
cudaMalloc((void**) &Dev_img_data , size_img_data );
cudaMalloc((void**) &Dev_Result_data , size_result_img_data );
//Reset
cudaMemset( Dev_img_data , 0 , size_img_data ) ;
cudaMemset( Dev_Result_data , 0 , size_result_img_data ) ;
//COPY
cudaMemcpy( Dev_img_data , img_data , size_img_data , cudaMemcpyHostToDevice) ;
cudaBindTexture( 0 , tex_img_data , Dev_img_data) ;
// Run Kernel Edge Detection //
int Calculation = width * height ;
int Basic_Block = Calculation/MAX_Threads + (0!=(Calculation%MAX_Threads)) ;
int Dev_Block = Basic_Block ;
Kernel_Share_Edge_Detect<<< Dev_Block , MAX_Threads >>>( width , height , Dev_Result_data , Basic_Block) ;
//COPY EDGE IMAGE to CPU
cudaMemcpy(Result_img , Dev_Result_data , size_result_img_data , cudaMemcpyDeviceToHost) ;
CUT_SAFE_CALL( cutStopTimer( total_timer));
total_elapsedTimeInMs = cutGetTimerValue( total_timer);
printf(" Edge Detection costs total time <<<%f ms>>> \n",total_elapsedTimeInMs);
CUT_SAFE_CALL( cutDeleteTimer( total_timer));
============= Edge_Detection_kernel.cu ======================
#include “Edge.h”
texture< unsigned char , 1 , cudaReadModeElementType> tex_img_data ;
global void
Kernel_Share_Edge_Detect(int width , int height , float *Dev_Result_data , int Basic_Block)
int tx = threadIdx.x ;
int bx = blockIdx.x ;
//Create Share Memory
__shared__ float S_Img_data[Height][Width] ;
int img_x = (bxMAX_Threads+tx) % width ;
int img_y = (bxMAX_Threads+tx) / width ;
S_Img_data(img_y , img_x) = (float)tex1Dfetch(tex_img_data , img_ywidth3+img_x*3+2 ); // <–error
__syncthreads() ;
//========== Horizontal ========//
float a = S_Img_data(img_y , img_x+1) - S_Img_data(img_y , img_x); // <–error
if( img_x <= (width-1) )
if(a>20 || a<-20)
Dev_Result_data[img_y*width + img_x] = 255 ;
__syncthreads() ;
//========== Vertical ========//
a = S_Img_data(img_y+1 , img_x) - S_Img_data(img_y , img_x); // <–error
if( img_y <= (height-1) )
if(a>20 || a<-20)
__syncthreads() ;
