I have a problem and two questions. I have noticed that in the folder /boot/extlinux/ there were two extlinux.conf* files:
the regular extlinux.conf that gets loaded at runtime.
a extlinux.conf.nv-update-extlinux-backup files that is generic, meaning without FDT or specific bootargs.
My questions are the following:
What is the purpose of extlinux.conf.nv-update-extlinux-backup?
If I change my extlinux.conf file and power cycle, can extlinux.conf.nv-update-extlinux-backup be silently copied or used by the bootloader instead of extlinux.conf?
My problem is the following:
I am under the impression that the silent copy can happen sometimes. Indeed, my Ubuntu install sometimes breaks when I modify my extlinux.conf file (even if the modification is valid), and booting using another media shows me that the content of extlinux.conf.nv-update-extlinux-backup is copied into extlinux.conf.
I am not sure of what causes this issue. Do you have any information about it?
I am curious, would it be possible to separate out the extlinux.conf from the nvidia-kernel package? I have to agree that this probably is causing some mysterious issues at times and should not be a package, although it should be a configuration. Configurations tend to preserve customizations.
An example, on desktop PC, is: /etc/default/grub
One can edit configuration of GRUB2 there, and although a kernel install will update the bootloader, customizations will remain. For example, the “quiet” parameter can be left out and adding a new package won’t delete that requirement. I believe there should be a similar setup in “/etc/default” for extlinux.conf rather than an absolute package content for extlinux.conf versus anything which might be customized in extlinux.conf(of course that would also mean a tool to update extlinux.conf…this is what the package currently does, although it has no customization).
