I’m using jetpack 32.7.1, the jetpack can create system.img first time. $ sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
But “after” we create the system.img, modify rootfs or something else, and create new system.img.
The “new” system.img will failed to setting up the ubuntu and hang forever.
(reboot can’t solved this issue.)
[ 12.772565] using random host ethernet address
[ 13.223430] using random self ethernet address
[ 13.223557] using random host ethernet address
[ 17.352002] Please complete system configuration setup on desktop to proceed...
If we didn’t remove kernel/Image.gz, this issue happens.
Please tell us why.
Also, for our custom jetpack.
I change the files mentioned above and run $ tar --exclude='./Linux_for_Tegra/sources' --numeric-owner -czpf ../demo_jetpack.tgz .
Extract the demo_jetpack and flash.
Turn out the demo_jetpack always gets the issue.
And the demo_jetpack can’t run $ sudo ./apply_binaries.sh.
joezhang@home:~/Downloads/test_jetpack_nvidia/20220822-30/Linux_for_Tegra$ sudo ./apply_binaries.sh
Using rootfs directory of: /home/joezhang/Downloads/test_jetpack_nvidia/20220822-30/Linux_for_Tegra/rootfs
||||||||||||||||||||||| ERROR |||||||||||||||||||||||
1. The root filesystem, provided with this package,
has to be extracted to this directory:
2. The root filesystem, provided with this package,
has to be extracted with 'sudo' to this directory:
Consult the Development Guide for instructions on
extracting and flashing your device.
