Jetson Module : Jetson Nano production(emmc 16gb)
JetPack/L4T : # R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
H/W : custom carrier board with 4 port usb To sata(JMicron 152d:0578)
I’m using JMicron usb to sata chip on my custom carrier board.
lsusb
Bus 002 Device 007: ID 058f:6387 Alcor Micro Corp. Flash Drive
Bus 002 Device 006: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp.
Bus 002 Device 005: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp.
Bus 002 Device 004: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp.
Bus 002 Device 003: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp.
Bus 002 Device 002: ID 0424:5807 Standard Microsystems Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0424:2807 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sometimes, I can’t see my usb_to_sata hdd/sdd storages after rebooting system.
Share the full dmesg when error happened and not happened instead of a photo of your connection… it really does not matter to us how your board “looks like”…
Try new jetpack release as usb firmware may have update.
I’ll suggest a full serial console boot log and not just dmesg log, with one log when it works, and one when it fails. In a working case I’ll also suggest showing the output of “lsblk -f”. Also, a working-versus-non-working “lsusb” and “lsusb -t”.
I saw some usb device returns -71 error. Could you check if that is your usb to sata device? And it is only in full speed.
[ 4.718218] usb 1-2: device descriptor read/64, error -71
[ 4.949932] usb 1-2: device descriptor read/64, error -71
[ 5.181832] usb 1-2: new full-speed USB device number 5 using tegra-xusb
[ 5.302237] usb 1-2: device descriptor read/64, error -71
