Hi!
I have a serious problem with my project.
I am implementing a forward mapping algorithm with CUDA.
I don’t think my code is wrong but sometimes I get wrong results.
Clearly, I ran the same code, but different results came out.
Here is my core code in my program.
//<<------------------------- Host code --------------------------->>
dim3 dimBlock(30,20,1);
dim3 dimGrid(xWidth / dimBlock.x, yHeight / dimBlock.y, 1);
for(i=0;i<TOTALVIEW-2;i++)
InitializeVirtualViewKernel<<< dimGrid, dimBlock, 0 >>>(d_OutView[i].m_pImageData,d_OutView[i].m_pDepthMap,xWidth,xWidthStep);
ForwardMappingKernel<<< dimGrid, dimBlock, 0 >>> (d_OutView[i].m_pInputCoef,d_pInputInfo,d_OutView[i].m_pImageData,d_OutView[i].m_pDepthMap,xWidth,yHeight,xWidthStep);
//<<------------------------- device code --------------------------->>
texture<float4, 2, cudaReadModeElementType> texCenterView;
__global__ void
InitializeVirtualViewKernel(unsigned char* d_pOutImage, unsigned char* d_pOutDepth, int xWidth, int xWidthStep)
unsigned int iX = blockIdx.x * blockDim.x + threadIdx.x;
unsigned int iY = blockIdx.y * blockDim.y + threadIdx.y;
d_pOutDepth[iY*xWidth + iX] = 0;
d_pOutImage[iY*xWidthStep + 3*iX + 0] = 0;
d_pOutImage[iY*xWidthStep + 3*iX + 1] = 0;
d_pOutImage[iY*xWidthStep + 3*iX + 2] = 0;
__global__ void
ForwardMappingKernel(MapCoef* d_pInputCoef, ViewInfo* d_pInputInfo, unsigned char* d_pOutImage, unsigned char* d_pOutDepth, int xWidth, int yHeight, int xWidthStep)
unsigned char cDisparity;
unsigned char vDisparity;
float zDepth;
unsigned int nX, nY;
unsigned char R,G,B;
float fU = iX / (float) xWidth;
float fV = iY / (float) yHeight;
float4 texData = tex2D(texCenterView, fU, fV);
B = (unsigned char) texData.x; // Blue
G = (unsigned char) texData.y; // Green
R = (unsigned char) texData.z; // Red
cDisparity = (unsigned char) texData.w; // Depth Disparity
zDepth = d_pInputInfo->Scale_D2Z * (cDisparity * d_pInputInfo->SSrl);
float fX = (float) iX;
float fY = (float) iY;
float t = d_pInputCoef->a9*fX + d_pInputCoef->a10*fY + d_pInputCoef->a11*zDepth + d_pInputCoef->a12;
  Â
float xCoor = (d_pInputCoef->a1*fX + d_pInputCoef->a2*fY + d_pInputCoef->a3*zDepth + d_pInputCoef->a4) / t + d_pInputCoef->a13;
float yCoor = (d_pInputCoef->a5*fX + d_pInputCoef->a6*fY + d_pInputCoef->a7*zDepth + d_pInputCoef->a8) / t + d_pInputCoef->a14;
if(xCoor < 0 || xCoor > xWidth-1 || yCoor < 0 || Â yCoor > yHeight-1)
                         return;
nX = (unsigned int) (xCoor + 0.5f);
nY = (unsigned int) (yCoor + 0.5f);
vDisparity = ((unsigned char*) d_pOutDepth)[nY*xWidth + nX];
if(cDisparity > vDisparity)
   d_pOutDepth[nY*xWidth + nX] = cDisparity;
d_pOutImage[nY*xWidthStep + 3*nX + 0] = B; // Blue
d_pOutImage[nY*xWidthStep + 3*nX + 1] = G; // Green
d_pOutImage[nY*xWidthStep + 3*nX + 2] = R; // Red
Two different result images are attached.
one is right, and the other is wrong.
what am I supposed to do for fixing my problem?
please help me…
Thank you.
32-bit Windows XP
CUDA toolkit release version 1.1
Visual Studio 2005
Geforce 8800GTS 512
!(upload://m21Gvb4z9yjLFkswYfuZApdLh1t.jpeg)
