Sonic on mellanox switch
Objective : sonic image should run on mellanox
I am trying to generate sonic pure image file for mellanox SN5xx series.
Reference followed : GitHub - sonic-net/sonic-buildimage: Scripts which perform an installable binary image build for SONiC
These are the files (no image file) in build target directory after above steps and able to make without any errors.
How can I generate image file for mellanox?
The image you should be using is the file “sonic-mellanox.bin” as shown in green in your screenshot. You should follow the onie install process from the switch
See also the following links:
I thought, we need a image file with extension .img
I will try with binary file once hardware is available.
THANK YOU for the reply.
