hello all,
i test a program when data number is 278994, thrust ::sort_by_key will run crush . and in other circle ,it is ok .
IsolationDeleteExe.exe 中的 0x7527a932 (KernelBase.dll) 处最可能的异常: Microsoft C++ 异常: 内存位置 0x00f2ea04 处的 thrust::system::system_error。
IsolationDeleteExe.exe 中的 0x7527a932 (KernelBase.dll) 处有未经处理的异常: Microsoft C++ 异常: 内存位置 0x00f2ea04 处的 thrust::system::system_error。
Hi!
I need a bit more information to look into this. If this is still a problem for you, please provide:
- A minimal test case; e.g. a complete, standalone program that is as small as possible and has few/no dependencies on other software.
- The entire sequence of commands/actions that reproduce the bug (using the minimal test case).
- The unabbreviated outputs of those commands/actions including files, stdout/stderr and logs.
- A description of the environment where the problem occurs (type and version of the hardware, OS, kernel, compiler and any other relevant software).
