Note that there are syntax differences in JP 5.0 compared to previos JP 4 versions and the bindings can not be directly pasted from earlier JP 4 DT files
Thank you for the quick answer!
Would you please also point us to the correct place where to define the audio routing?
We can see the format/syntax examples like this one:
nvidia,audio-routing =
“Headphone-x”, “x OUT”,
“x IN”, “LineIn-x”,
“Headphone-y”, “y OUT”,
“y IN”, “LineIn-y”,
“Headphone-d”, “d OUT”,
“d IN”, “LineIn-d”,
“BT-out”, “b OUT”,
“b IN”, “BT-in”,
“EAVB-out”, “ADSP EAVB Transmit”,
“ADSP EAVB Receive”, “EAVB-in”;
But it is not clear where exactly such definition(s) should reside.
nvidia-audio-card,routing in sound node is the relevant property to place the DAPM routes. Link provides deatils on how the DAPM routes should be framed. This was available as part of the documentation links provided in earlier comment as well. Urge you to read through the documentation
