Is source code (.cpp file) of nvbuf_utils.h
which is part of Multimedia API available somewhere?
I would be interested in logic behind NvBufferCreateEx
and NvBufferTransform
to see how is DMA buffer created / copied.
Thanks in advance.
Richard
The implementation is in
/usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so
Unfortunately the prebuilt lib is not open source. Sorry for it.
Hi @DaneLLL , do you know what is happening behind those procedures, just theoretically? To my understanding it should be some dma_buf management, right? Do you have more details? E.g. how does the NvBufferCreateParams
affects the DMA buffer, espacially nvbuf_tag
and payloadType
Thank You
nvbug_tag
is for debugging/tracing purpose. It does not have impact for functionality. But for traceability, suggest set it accordingly.
payloadType
is set to NvBufferPayload_SurfArray
along with NvBufferColorFormat
. There should be no use-case to set to NvBufferPayload_MemHandle
Most use-cases are demonstrated in the samples. Please take a look at
/usr/src/jetson_multimedia_api/
