for file source we use,
source = gst_element_factory_make ("filesrc", "file-source");
g_object_set (G_OBJECT (source), "location", input_file, NULL);
how to use CSI camera feed in jetson nano ?
For CSI camera, the plugin is nvarguscamerasrc. you may check code of source bin in
deepstream_sdk_v4.0.1_jetson\sources\apps\apps-common\src\deepstream_source_bin.c
You may also run deepstream-app:
deepstream-app -c source1_csi_dec_infer_resnet_int8.txt
There is a sample config file for CSI camera:
deepstream_sdk_v4.0.1_jetson\samples\configs\deepstream-app\source1_csi_dec_infer_resnet_int8.txt
