0:01:08.378639504 23885 0x3148c980 WARN nvinfer gstnvinfer.cpp:1705:gst_nvinfer_process_objects: Source info not found for source 2. Maybe the GST_NVEVENT_PAD_ADDED event was never generated for the source.
0:01:08.394033843 23885 0x3148caa0 WARN nvinfer gstnvinfer.cpp:1705:gst_nvinfer_process_objects: Source info not found for source 1. Maybe the GST_NVEVENT_PAD_ADDED event was never generated for the source.
0:01:08.394058108 23885 0x3148c8c0 WARN nvinfer gstnvinfer.cpp:1705:gst_nvinfer_process_objects: Source info not found for source 1. Maybe the GST_NVEVENT_PAD_ADDED event was never generated for the source.
0:01:08.413693848 23885 0x22bc08c0 WARN nvinfer gstnvinfer.cpp:1705:gst_nvinfer_process_objects: Source info not found for source 2. Maybe the GST_NVEVENT_PAD_ADDED event was never generated for the source.
0:01:08.413718584 23885 0x22bc0800 WARN nvinfer gstnvinfer.cpp:1705:gst_nvinfer_process_objects: Source info not found for source 2. Maybe the GST_NVEVENT_PAD_ADDED event was never generated for the source.
0:01:08.420194007 23885 0x3148c980 WARN nvinfer gstnvinfer.cpp:1705:gst_nvinfer_process_objects: Source info not found for source 2. Maybe the GST_NVEVENT_PAD_ADDED event was never generated for the source.
0:01:08.421480022 23885 0x3148caa0 WARN nvinfer gstnvinfer.cpp:1705:gst_nvinfer_process_objects: Source info not found for source 1. Maybe the GST_NVEVENT_PAD_ADDED event was never generated for the source.
0:01:08.421515776 23885 0x3148c8c0 WARN nvinfer gstnvinfer.cpp:1705:gst_nvinfer_process_objects: Source info not found for source 1. Maybe the GST_NVEVENT_PAD_ADDED event was never generated for the source.
Hi, I am trying to run the deepstream parallel inference using python, but when I try to run three PGIE branches .
I am getting the above error.
• DeepStream Version
• TensorRT Version
• The pipeline being used
• Hardware Platform GPU
• DeepStream Version -----> 6.2
• TensorRT Version 8.5
• NVIDIA GPU Driver Version 535
Lets consider I have A, B, C, D PGIE’s.
when I try to use A, and B, I don’t encounter this. But when I use C, D I am getting this warning.
Okay, let me share my configs.
I have tried modifying configuration file to run four-way parallel inferences using deepstream_parallel_infer_app as your description. It can work normal.
From the logs you provided, I guess the problem is that streammux is not successfully linked with nvinfer
