Source_sync.sh fails with HTTP 502
I am running the source_sync.sh as
./source_sync.sh -t tegra-l4t-r32.5.1
I had an error similar to https://forums.developer.nvidia.com/t/source-sync-is-failing/192695, which would say:
nv-tegra.nvidia.com[0: 35.82.181.43]: errno=Connection timed out
nv-tegra.nvidia.com[1: 34.216.216.36]: errno=Connection timed out
After referring to the same post, I changed the source_sync.sh, line 327, from git:// to https://
Now I get the following error:
error: RPC failed; HTTP 502 curl 22 The requested URL returned error: 502 Proxy Error
fatal: The remote end hung up unexpectedly
I’ve also tried running the script from different wifi connections and different machines, but the errors are consistent all throughout.
Does anyone ever had a similar error and/or knows of a potential fix?
Thanks,
Francisco Zacarias
Turns out it was the same solution as the post I mention, only that instead of https://, I had to change it to http:// . It worked as intended now, AFAIK.
Good to know issue resovled.
