source_sync.sh -k fail
I want to get TX1 kernel source. Already open 9418 port.
jhan@jhan-linux:~/nVidia/document/Linux_for_Tegra$ sudo ufw status
상태: active
To Action From
9418 ALLOW Anywhere
80 ALLOW Anywhere
22 ALLOW Anywhere
443 ALLOW Anywhere
13337 ALLOW Anywhere
161 ALLOW Anywhere
9418/tcp ALLOW Anywhere
22/tcp ALLOW Anywhere
Samba ALLOW Anywhere
9418 (v6) ALLOW Anywhere (v6)
80 (v6) ALLOW Anywhere (v6)
22 (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
13337 (v6) ALLOW Anywhere (v6)
161 (v6) ALLOW Anywhere (v6)
9418/tcp (v6) ALLOW Anywhere (v6)
22/tcp (v6) ALLOW Anywhere (v6)
Samba (v6) ALLOW Anywhere (v6)
[b]jhan@jhan-linux:~/nVidia/document/Linux_for_Tegra$ sudo ./source_sync.sh -k
Downloading default kernel source…
Cloning into ‘/home/jhan/nVidia/document/Linux_for_Tegra/sources/kernel_source’…
fatal: unable to connect to nv-tegra.nvidia.com:
nv-tegra.nvidia.com[0: 216.228.121.37]: errno=timeout
/home/jhan/nVidia/document/Linux_for_Tegra/sources/kernel_source source sync failed![/b]
How to access github??
This wiki could help you:
https://developer.ridgerun.com/wiki/index.php?title=Compiling_Tegra_X1_source_code
A wiki like this will help everyone for TX1 development. Useful information is scattered in this forum and difficult to search and find.
I added “ridgerun.com” to my bookmarks.
I got the same error when “source_sync” from work, but it worked on the same laptop from home.
I believe it’s firewall issue.
I can connect “nv-tegra.nvidia.com” site using firefox browser.
But, source_sync.sh command is not access nv-tegra.nvidia.com.
Is this also firewall issue?
The following was yesterday from work:
ubuntu@ubuntu-HP-ZBook-15:~/L4T/l4t23.2/Linux_for_Tegra$ ./source_sync.sh -k tegra-l4t-r23.2
Downloading default kernel source...
Cloning into '/home/ubuntu/L4T/l4t23.2/Linux_for_Tegra/sources/kernel_source'...
nv-tegra.nvidia.com[0: 216.228.121.37]: errno=Connection timed out
/home/ubuntu/L4T/l4t23.2/Linux_for_Tegra/sources/kernel_source source sync failed!
The following is today from home:
remote: Counting objects: 3358095, done.
remote: Compressing objects: 100% (572114/572114), done.
remote: Total 3358095 (delta 2771964), reused 3341856 (delta 2755865)
Receiving objects: 100% (3358095/3358095), 770.90 MiB | 4.39 MiB/s, done.
Resolving deltas: 100% (2771964/2771964), done.
Checking connectivity... done.
The default kernel source is downloaded in: /home/ubuntu/L4T/l4t23.2/Linux_for_Tegra/sources/kernel_source
Syncing up with tag tegra-l4t-r23.2...
Checking out files: 100% (46202/46202), done.
Switched to a new branch 'mybranch_2016-04-27-1461753964'
/home/ubuntu/L4T/l4t23.2/Linux_for_Tegra/sources/kernel_source source sync'ed to tag tegra-l4t-r23.2 successfully!
Your company/ISP or router may have blocked port/protocol of nvidia git server which use different port/protocol from “http://nv-tegra.nvidia.com
There is the eLinux wiki at http://elinux.org/Jetson_TX1, but it’s not as well organized or as informative as the TK1 wiki at this point.
Camera support has not been included in the above wiki. A wiki from patch kernel to run camera apps would be very helpful.
