Rather than solder the main board to short R313 and have the system boot on power-on, I’d like to plug a modified bit of flex cable into J27. The cable is a 0.8mm pitch 10 contact one sided.
Does anyone know where I can source this? Not available from digikey or mouser.
That’s an actual connector…not for flat flex cable. I see the part number is “50208-01001-001”.
I found this description which might be of interest:
https://www.datasheets360.com/part/detail/50208-01001-001/-4477551219374466332/
Docs show this as made by “Aces Electronic Co., Ltd.”. Unfortunately I wasn’t able to find the mating connector number.
Ah - you are correct! There is a mating connector shown. Thanks!
So now we are looking for a mating connector, @nvidia?
I found this discussion in this forum:
https://devtalk.nvidia.com/default/topic/976589/-auto-power-on-support/
which I suppose is the official answer.
