Spacer Requirement for Mounting Jetson Xavier Module
HUDL is using the following connector to mount our Jetson Xavier NX module (on the Flex camera) to their host system:
TE Connector spec: 2309413-1
TE’s specification calls out that the card slot center is 7.30+0.25/-0 mm from the surface of the host PCB ie see Section A-A as follows:
Section A-A Page 1 of spec
Center of Card slot to Top surface of mounting PCB: 7.3 +0.25/-00 (7.35 – 7.
The NVIDIA specification for board thickness is 1.2+/-0.12mm. As per Page 43 of Jetson_Xavier_NX_Product_Design_Guide_DG-09693-001_v1.7.pdf
So using TE Connectivity’s connector solution, we have:
Max distance of NVIDIA module to PCB separation:
7.55 – (1.2-0.12)/2 = 7.01mm
Min distance of NVIDIA module to PCB separation:
7.35 – (1.2+0.12)/2 = 6.69mm
Hence distance tolerance can be expressed as:
6.85 +/-0.16 mm
The NVIDIA module spec calls out 6.57±/0.1mm spacer for a 9.2mm height connector. TE Connectivity calls out the connector we use as a 9.3mm height. As per Page 9 of
Hence, I have the following question: Does NVIDIA see any concern in this arrangement with using a 6.5 +/-0.1 spacer? This solution represents the most easily sourced/manufactured outcome. Other solutions which land the spacing in the middle of the tolerance range either require a custom part or an extra part ie washer which is difficult to assemble. So hoping you have a view regarding the use of a 6.5mm spacer only.
We don’t have other recommendation than the components in Design Guide and SCL.
It is in our SCL, should be no problem.
I’m more asking what height the spacer needs to be when using that specific connector?
The connector used on devkit is also 2309413-1, you can use the same spacer for design.
Jetson Xavier NX Developer Kit Carrier Board Specification (P3509 A01)
