Spark Studio — Open-source inference dashboard for DGX Spark
One-command install:
Bash
bash <(curl -fsSL https://raw.githubusercontent.com/TheAwaken1/Spark-Studio/main/install.sh)
Launch vLLM, SGLang, llama.cpp, or sparkrun recipes from a clean UI. Monitor unified memory live, chat with models, run benchmarks — and if something breaks or runs slow, the built-in agent (Claude Code / Codex — uses your own subscription) will diagnose, patch, and relaunch it automatically.
Includes multi-node cluster view (no node limit), MIT licensed.
→ GitHub - TheAwaken1/Spark-Studio: DGX Spark inference dashboard — vLLM, SGLang, llama.cpp, WebGPU & sparkrun with agent-powered Auto-Fix and speed optimization · GitHub
Found a bug? Just hit the Copy Bug Report button and paste it straight into a GitHub issue.
Feedback and stars always welcome 🔥
Use the set-up wizard or not!
Have your model search the web with SearXNG
Recipes pulled from Sparkrun
Test the models coding capabilities, with built in canvas to view/play
That looks nice man! Will checck it out!
Just spent some time digging into Spark-Studio — really nice work, and thanks for putting it out under MIT.
The pre-launch memory guard is such a good call for unified memory — actually stopping models, waiting for reclaim, and refusing launches that won’t fit saves you from the usual OOM chaos on 128 GB setups. The Auto-Fix loop using local claude/codex CLIs is also super practical — logs in, patch, retry, no extra setup. And I like that Optimize Speed is strictly measurement-based (≥10% or it rolls back), plus the restart-proof workload handling — those are the kinds of details that make this solid.
Many thanks
Mark
Thanks for the feedback. I’ve been working on this for a while; the reason I created this app was to launch models easily and get up and running. I made this app as user friendly as possible, with loading and offloading models without issues, with the ability to optimize them. You can also go to spark arena click on a model:
click on share and copy text
Copy and paste it in Recipe tab and click run
You built the dashboard I’ve been wanting to make. Thanks for sharing.
No problem. Well now you can take this and tweak it to your liking :).
Also, you can run this on any of your devices on your network, just click on the IP and use the provided IP addresses on any device even on your phone, I was using my iPhone yesterday lol
Ok now this is cool. Just installed and tinkering for now. Trying to see how sparkrun integrates with it. Is it supposed to have a spark-run section on the sidebar?
Thanks. Go to recipe’s tab and you’ll see sparkrun community recipes. You can also copy and paste recipes from spark-arena
Very cool tool… I built everything in scripts and used glances to monitor - wanted to be very lightweight to keep as much RAM available for models. How much RAM does this tool use itself?
Thank you. I actually just checked by using this command:
ps aux | grep uvicorn
I had 3 instances of spark-studio running lol with 61400, 70492 & 88696 KB so roughly 60-90MB of ram per instance.
I have sparkrun installed and Spark Studio is not see it.
try the below and Ctrl+Shift+R once its restarted.
# 1. Stop the service
systemctl --user stop spark-studio
2. Kill any leftover processes (important)
pkill -f "uvicorn server:app"
sudo fuser -k 7860/tcp 2>/dev/null || true
3. Restart the service
systemctl --user restart spark-studio
4. Check status
systemctl --user status spark-studio
5. Check if UI is live
./start.sh --doctor
That worked, thanks
All,
you can also ask the Engine chat to create a word document or excel document, if the model is smart enough it will create one
A beautiful piece of work.. Thank you..
Hopefully you are enjoying it, thanks for the kind words. PS: make sure you update, been adding and fixing some small issues:
./start.sh --update
then:
1. Stop the service
4. Check status
./start.sh --doctor
Messing around with a multimodal speech model. This is a rough draft/prototype lol. Got it to navigate different tabs and even run a recipe. Voice is still funky at times, but it has potential, plus it’s small enough that I had it running with a recipe at the same damn time, my voice is on helium lol
Voice model: LFM2.5‑Audio-1.5B
I have the same problem, but when I run Spark Studio not from service - all OK.
Have you tried:
./start.sh --update
then:
1. Stop the service
4. Check status
./start.sh --doctor
also, Cntrl+Shift+R to refresh
I’ve been trying the app out. What’s the preferred way to pass Huggingface token?
