How do you set the custom model location for sparkrun and stop it downloading on every run and make it only sync when needed? I found how to select the node ips it will run on.
Related topics
| Built a tool for managing model serving on Sparks and Spark Clusters, PRs welcome | 3 | 468 | July 16, 2026 | |
| Sparkrun - central command with tab completion for launching inference on Spark Clusters | 97 | 6070 | September 24, 2026 | |
| Made this to make using sparkrun on one or two sparks a little more fun | 1 | 382 | July 3, 2026 | |
| Spark: one script CLI for setup, remote access, and LLM serving on DGX Spark | 3 | 926 | May 21, 2026 | |
| Spark Studio — Open-source inference dashboard for DGX Spark | 29 | 5302 | August 14, 2026 | |
| Value of 2nd Spark? | 21 | 4290 | March 30, 2026 | |
| Simple frontend webui for Sparkrun for multiple GB10s | 0 | 306 | July 12, 2026 | |
| Save your spark cluster disk space, use this solution | 15 | 1620 | July 24, 2026 | |
| Managing Local LLM Orchestration | 12 | 4994 | April 23, 2026 | |
| Moving the spec-decode draft model off your Sparks onto external 30xx GPU | 1 | 245 | September 29, 2026 |
