I am getting the following error when attempting to build the SPE on my Ubuntu 22.04 64bit VM.
mkdir -p /home/parallels/nvdia/spe-freertos-bsp/rt-aux-cpu-demo-fsp/out/t19x
CC clk.c
/home/parallels/nvdia/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc: 1: ELF: not found
/home/parallels/nvdia/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc: 1: Syntax error: Unterminated quoted string
make: *** [Makefile:325: /home/parallels/nvdia/spe-freertos-bsp/rt-aux-cpu-demo-fsp/out/t19x/clk.o] Error 2
I downloaded and unzipped the files using ‘tar -xpf’ command. I assume it is something to do with being a 64 bit build/machine, but can’t figure out how I would resolve the issue.
I found one similar issue that mentioned using tar -xpf to unzip the files, but as noted that didn’t work.
Note that I set SPE_FREERTOS_BSP and CROSS_COMPILE env variables as noted in the instructions.
