Spec file for EfficientNet-B0 for Detectnet_V2 Object Detection
• Hardware (T4/V100/Xavier/Nano/etc) - Xavier
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) - Detectnet_V2
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here) - 3.22.02
Hello everyone,
I would like to train an object detection model using efficientnet_b0 model. When I run the following command
!ngc registry model list nvidia/tao/pretrained_detectnet_v2:*
I get two efficientnet_b0 models - efficientnet_b0_swish and efficientnet_b0_relu
However, when I am creating the model config section in the spec file, the arch parameters take only the following values : resnet, vgg, mobilenet _v1, mobilenet _v2, googlenet
Can you share a sample spec file for efficientnet_b0 models which can be used as reference?
Looking forward to your replies !!
The detectnet_v2 network support below backbones. It does not support efficientnet backbone.
See DetectNet_v2 — TAO Toolkit 3.22.02 documentation
Thanks for the information !!
