Speed and Frame rate on Jetson Nano
Hi
I am quite new to Jetson. I want to use Jetson for an application where I need to process and detect objects on a conveyor belt that is moving at a speed of 0.3m/s with camera mounted 1 meter above the belt.
Is Jetson Nano/Xavier fast enough to detect objects in real time with the mentioned moving speed?
Based on our performance table below, you can run detection with 43fps (Nano) or 1602fps (Xavier).
