Is there a built-in method in DeepStream 6.2 to calculate object speed using tracking data, or should I compute it manually from NvDsObjectMeta
positions across frames? Any suggestions?
Do you mean speed in pixels or actual distance travelled in km/hr? for the latter you will need very situation specific calibration (homography) to be able to do that. The perspective of the camera can vary quite a lot and this calibration will have to be done individually for your case.
Can you share more on your use case?
I’d like to get speed in pixels please.
The use case: detection of static objects
Using DS 7.0
Possible?
