I’m comparing the performance of atomic operations in double precision arithmetics between a Fermi GT540M card and a Kepler K20.
I have a kernel performing, among other operations, atomic additions. I’m using the device function
__device__ double atomicAdd(double* address, double val)
unsigned long long int* address_as_ull =
(unsigned long long int*)address;
unsigned long long int old = *address_as_ull, assumed;
do {
assumed = old;
old = atomicCAS(address_as_ull, assumed,__double_as_longlong(val +
__longlong_as_double(assumed)));
} while (assumed != old);
return __longlong_as_double(old);
The presentation Inside Kepler at http://developer.download.nvidia.com/GTC/PDF/GTC2012/PresentationPDF/S0642-GTC2012-Inside-Kepler.pdf
promises 2-10x speedup, but I observe about 1.3.
I recognize that the speedup depends also on the other operations performed by the kernel, but my question is: I’m using the right way to deal with atomic operations in double precision arithmetics on a K20, or there exists, for that architecture, a faster way?
Thank you very much for any advice.
