Hello everyone,
I’m having issues with some latency in our GStreamer pipeline and I cannot find any additional resources with helpful information on how to reduce or eliminate it. Does anyone know any additional GStreamer resources on their pipelines or other methods to achieve this goal? Here’s the pipeline I have and we’re streaming three cameras simultaneously, but there’s an approximate 0.5 second lag.
DISPLAY=:0 gst-launch-1.0 nvcamerasrc sensor-id=0 fpsRange="30 30" ! 'video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)I420, \
framerate=(fraction)30/1' ! nvegltransform ! nveglglessink nvcamerasrc sensor-id=2 fpsRange="30 30" ! 'video/x-raw(memory:NVMM), width=(int)640, \
height=(int)480, format=(string)I420, framerate=(fraction)30/1' ! nvegltransform ! nveglglessink nvcamerasrc sensor-id=1 fpsRange="30 30" ! 'video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)I420, framerate=(fraction)30/1' ! nvegltransform ! nveglglessink -e
The reason I’m needing to speed this up is because I’m trying to make sure we’ve optimized our pipeline before the rest of my code that stitches the feeds together. When I put the above pipeline into C++ code and use the stitching function there’s a major lag in producing a streaming stitched output. My code is below and I was hoping to get some help and also resources on how to improve this. I’ve worked on this for a while and this isn’t the first version for the software.
I’m also having an issue when trying to get three camera inputs for the stitched feed. The feed only shows two cameras and then if I put my hand in front of the third camera it’ll show that image for a few seconds and then go back to the other two-camera feed.
I’m also not convinced that it isn’t my setup for Jetpack and/or the utilization other software applications. I’m utilizing “./jetson_clocks.sh” and “nvpmodel -m 0” every time I run the Jetson TX2.
#include <opencv2/opencv.hpp>
#include <opencv2/stitching.hpp>
#include <iostream>
#include <vector>
using namespace std;
using namespace cv;
Stitcher::Mode mode = Stitcher::PANORAMA;
int streaming(VideoCapture cap1, VideoCapture cap2)
Mat fr1, fr2, copy1, copy2, pano;
bool try_use_gpu = true;
vector<Mat> imgs;
cap1 >> fr1;
cap2 >> fr2;
imgs.push_back(fr1);
imgs.push_back(fr2);
Ptr<Stitcher> test = Stitcher::create(mode, try_use_gpu);
Stitcher::Status status = test->stitch(imgs, pano);
if (status != Stitcher::OK)
cout << "Error stitching - Code: " <<int(status)<<endl;
return -1;
imshow("Stitched Image", pano);
if(waitKey(1) >= 0)
return -1;
int main(int argc, char *argv[])
VideoCapture cap1("nvcamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)I420, framerate=(fraction)30/1 ! nvvidconv flip-method=0 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink", CAP_GSTREAMER); //middle output
VideoCapture cap2("nvcamerasrc sensor-id=2 ! video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)I420, framerate=(fraction)30/1 ! nvvidconv flip-method=0 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink", CAP_GSTREAMER); //output closest to center of board
if(!cap1.isOpened()){
cout << "connection cap1 failed" << endl;
return -1;
if(!cap2.isOpened()){
cout << "connection cap2 failed" << endl;
return -1;
while(true)
int test = 0;
test = streaming(cap1, cap2);
cout << "test: " << int(test) << endl;
return 0;
Thanks for any help and advice.
