Hi, what should i do now? I followed the steps and im using jetpack 4.2 32.1.0 i made the edits necessary but it failed
LD kernel/built-in.o
real 2m0.265s
user 5m17.660s
sys 0m26.012s
Make did not build
Retrying …
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
make[1]: ‘include/generated/mach-types.h’ is up to date.
CHK include/generated/bounds.h
CHK include/generated/timeconst.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
CC arch/arm64/kernel/topology.o
arch/arm64/kernel/topology.c: In function ‘parse_cluster’:
arch/arm64/kernel/topology.c:114:40: error: ‘%d’ directive output may be truncated writing between 1 and 10 bytes into a region of size 3 [-Werror=format-truncation=]
snprintf(name, sizeof(name), “cluster%d”, i);
arch/arm64/kernel/topology.c:114:32: note: directive argument in the range [0, 2147483647]
arch/arm64/kernel/topology.c:114:3: note: ‘snprintf’ output between 9 and 18 bytes into a destination of size 10
arch/arm64/kernel/topology.c:129:37: error: ‘%d’ directive output may be truncated writing between 1 and 10 bytes into a region of size 6 [-Werror=format-truncation=]
snprintf(name, sizeof(name), “core%d”, i);
arch/arm64/kernel/topology.c:129:32: note: directive argument in the range [0, 2147483647]
arch/arm64/kernel/topology.c:129:3: note: ‘snprintf’ output between 6 and 15 bytes into a destination of size 10
arch/arm64/kernel/topology.c:59:39: error: ‘%d’ directive output may be truncated writing between 1 and 10 bytes into a region of size 4 [-Werror=format-truncation=]
snprintf(name, sizeof(name), “thread%d”, i);
arch/arm64/kernel/topology.c:59:32: note: directive argument in the range [0, 2147483647]
arch/arm64/kernel/topology.c:59:3: note: ‘snprintf’ output between 8 and 17 bytes into a destination of size 10
cc1: all warnings being treated as errors
scripts/Makefile.build:261: recipe for target ‘arch/arm64/kernel/topology.o’ failed
make[1]: *** [arch/arm64/kernel/topology.o] Error 1
Makefile:973: recipe for target ‘arch/arm64/kernel’ failed
make: *** [arch/arm64/kernel] Error 2
Make did not successfully build
Please fix issues and retry build
jetson@jetson-desktop:~/buildJetsonTX2Kernel$
Could you also please ask them to write proper documentation AND include the SPI by default in the next build? If a hobby grade hardware like the raspberry pi can do it, certainly a jetson should.
I also have a huge compiled list of game breakers for us in case they are interested.
This word document shows me nothing about enabling SPI
Do you have a document with exact steps to follow so I can enable SPI on my Jetson TX2?
I have bricked and re flashed my Jetson 3 times today by following that tutorial on elinux website which is a very bad and dangerous tutorial
Where can I find straightforward instructions to enable SPI on my Jetson TX2 running jet pack 4.2?
Do you have that document please? We are desperately trying to make this work
Right now I have to go to one thread and then go to another to follow newer instructions and it still does not work
Do I really need to recompile the kernel to use SPI? Really? Did you guys think this through when you were designing this device? Did you guys also know that raspberry pi, a far inferior device and cheap hobby kit has SPI… while an expensive Nvidia Jetson does not and we have to recompile the kernel and earn a PhD in Linux administration to be able to use the damn thing.
For J4.2 you don’t need to rebuild the kernel Image but must edit the dtc like the elinux tell like below.
Update The Device-Tree
Use your text editor of choice to update the DTS that we decompiled above:
$ sudo gedit myTX2DeviceTreeSource.dts
Make the following patches:
spi@3240000{
compatible = "nvidia,tegra186-spi";
reg = <0x0 0x3240000 0x0 0x10000>;
linux,phandle = <0x80>;
spi@0 {
compatible = "spidev";
reg = <0x0>;
spi-max-frequency = <0x1312D00>;
nvidia,enable-hw-based-cs;
nvidia,cs-setup-clk-count = <0x1e>;
nvidia,cs-hold-clk-count = <0x1e>;
nvidia,rx-clk-tap-delay = <0x1f>;
nvidia,tx-clk-tap-delay = <0x0>;
Recompiling the Device Tree
Use DTC again to recompile the modifying DTS back into the new DTB:
$ cd /boot/dtb/
$ sudo dtc -I dts -O dtb -o tegra186-quill-p3310-1000-c03-00-base.dtb extracted_proc.dts
Enabling the New DTB
It's better flash the DTB by flash command instead of modify the extlinux due plugin manager will broken may cause unknow problem like break the network interface. Below is the command flash the DTB only.
sudo ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1
same problem here. Please help. After the make process completes, I cannot create the zImage file in the /usr/src/kernel/kernel-4.4/arch/arm64/boot folder using sudo ./copyImage.sh command.
