In Kernel source, in path, Documentation/devicetree/bindings/spi/spi-bus.txt
- spi-cpol - (optional) Empty property indicating device requires
inverse clock polarity (CPOL) mode - spi-cpha - (optional) Empty property indicating device requires
shifted clock phase (CPHA) mode - spi-cs-high - (optional) Empty property indicating device requires
chip select active high - spi-3wire - (optional) Empty property indicating device requires
3-wire mode. - spi-lsb-first - (optional) Empty property indicating device requires
LSB first mode. - spi-lsbyte-first - (optional) Empty property indicating device requires
Least Significant Byte first mode. - spi-tx-bus-width - (optional) The bus width(number of data wires) that
used for MOSI. Defaults to 1 if not present. - spi-rx-bus-width - (optional) The bus width(number of data wires) that
used for MISO. Defaults to 1 if not present.
How to assign these values? Getting little bit confusions.
The device values:
spi-cpol => Falling edge comes first, inverse values, i.e. CPOL = 1
spi-cpha => Data is valid in low to high transition, CPHA = 1
spi-cs-high => Chip select active low
spi-3wire => The device uses CS, Clk, MoSi
spi-lsb-first => Most significant bit first
spi-lsbyte-first => Use only one byte, then what value for this.
spi-tx-bus-width => only one Mosi used
spi-rx-bus-width => Not used.
The device node is as:
/* spi4 controller */
spi@3240000 {
status = "okay";
spi_device@0{
compatible = "driver_name";
status = "okay";
reg = <0>; /* chip select */
spi-max-frequency = <16000000>;
controller-data{
nvidia,enable-hw-based-cs;
//nvidia,cs-setup-clk-count = <0x1e>;
Have the below doubts?
spi-cpol => define or empty ???
spi-cpha => define or empty ???
spi-cs-high => define or empty ???
spi-3wire => define or empty ??? Used only CS, CLK, Mosi. Then what is this value?
spi-lsb-first => define or empty ???
spi-lsbyte-first => define or empty ??? Use only one byte, then what value for this.
spi-rx-bus-width => define or empty ??? Not used this, then what value for this.
Thanks for the reply.
Looking into spi bus core (spi.c) and spi-tegra114.c files.
-Thanks.
