I am using SPI to communicate with a device that requires clock idle low (Mode0)
Using a logic analyser I can see that after the data has finished clocking out there is some sort of hold time where the clock and chip select stay low for a while then the clock goes high then the chip select goes high.
The fact that the clock reverts back to high BEFORE the chip select de-asserts is causing issues.
The following command produces this behaviour
sudo ./spidev_test -D /dev/spidev0.0 -s 300 -H
Any ideas as to why this happens?
Here is a screenshot of the issue - Screenshot-2019-07-16-at-15-15-50 — ImgBB
Top trace is Clock
Bottom trace is Chip Select
from further testing I have also found that after a reboot the clock line stays low after each command, therefore the chip select is valid. It is only after I issue a command that requires clock idle high that the chip select line then always reverts back to high after every command.
I have looked through the driver and cannot find any cause, although it looks like the actual timing is up to the hardware not the driver.
Thanks for your report.
May need time to investigate it. Will update to you later.
