y.kim
February 9, 2023, 12:09am
1
I am trying to connect a IMU sensor to Jetson development kit using 40 extension headers.
I inserted spidev
module manually.
When I connect SPI miso and mosi, it works fine by spidev_test command.
But it doesn’t work with the IMU sensor.
Through the scope, I found the SPI CS is not changing at all.
I think the signal itself is not stable.
This is the the CS and SCK when there is no signal:
This is the one in SPI traffic:
This is the os version:
ykim@ubuntu:~$ uname -a
Linux ubuntu 5.10.104-tegra #1 SMP PREEMPT Wed Aug 10 20:17:07 PDT 2022 aarch64 aarch64 aarch64 GNU/Linux
ykim@ubuntu:~$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 1.0, GCID: 31250864, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 11 03:40:29 UTC 2022
ykim@ubuntu:~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="20.04.4 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.4 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
ykim@ubuntu:~$ lsmod | grep spi
spidev 28672 0
qspi_mtd 28672 0
mtd 69632 4 cmdlinepart,qspi_mtd,ofpart
spi_tegra114 32768 0
spi_tegra210_qspi 28672 0
In 40-pin expansion header, there is SPI1 and SPI3. Which one do oyu use in your use-case? And not sure if you use developer kit or your own custom board. For using developer kit, you can generate the device tree enabling SPI1/SPI3 through jetson-io.py
y.kim
February 9, 2023, 2:08am
4
I am using SPI1.
DOUT: 19
DIN: 21
SCK: 23
CS0: 24
They were enabled by default for me:
I am using the devkit!
DaneLLL
February 10, 2023, 8:33am
5
The default setting for SPI1and also SPI3) is
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x10>;
nvidia,tx-clk-tap-delay = <0x0>;
Please try to tune the setting and see if there is improvement. May try rx-clk-tap-delay = 0xF or 0x11, tx-clk-tap-delay = 0x1 or 0x2. And may remove enable-hw-based-cs for a try.
y.kim
February 15, 2023, 4:05am
6
Hi, I need to use the nvidia,cs-inactive-cycles
option, which means I have to enable enable-hw-based-cs
. I think your advice is not an option for me.
This is what I did to find out the pin problem:
SPI0_SCK: gpio491, SPI0_CS0: gpio494
export two gpio ports by this command:
# echo 491 > /sys/class/gpio/export
# echo 494 > /sys/class/gpio/export
# cd /sys/class/gpio/export
# cd gpio491
# echo out > direction
# cd ../gpio494
write 0 and 1 to value
of each gpio then check the signal in the scope
I can see the change for SPI0_SCK
but I can’t see it for SPI0_CS0
Here are the output of the scope:
[Both are 0]
[Both are 1]
Can you help me?
DaneLLL
February 16, 2023, 5:08am
7
The pins may not work properly if you configure them as SPI pins and GPIO pins at the same time. Could you also try to set the properties:
nvidia,cs-setup-clk-count
nvidia,cs-hold-clk-count
nvidia,clk-delay-between-packets
And check if you can see signals in CS0 and SCK pins when communicating with the IMU sensor.
If there is still no signals, please connect miso and mosi and then run
$ ./spidev_test -D /dev/spidev0.0 -v
You have confirmed this test works. Please check if there is signals in CS0 and SCK pins in the test.
system
Closed
March 2, 2023, 5:08am
8
