SPI GPIO chipselect lines not working
I’ve been attempting to add additional chipselect lines to the SPI on the AGX’s 40-pin header. I’ve added an entry for the cs-gpios field in the device tree for the SPI controller as per the documentation in the linux device tree documentation and accordance with this forum post: TX2 R28.2 SPI CS-GPIO issue
Are there any known issues with using cs-gpios with the AGX? Is there any special configuration required for the GPIOs in order to have them used by the SPI controller?
Could you trace the …/kernel/kernel-4.9/drivers/spi/spi-gpio.c to confirm the configure.
Thanks for your reply. I’ll report back tomorrow with my findings.
