In the TX1 TRM, the SPI Interrupt Mask Register (37.3.13) is confusing. For each bit mentions both.
0 = Enable interrupt …
1 = Disable interrupt …
0 = DISABLE
1 = ENABLE
So is it 0 to Disable and 1 to Enable? Or?
0 = DISABLE
1 = ENABLE
Yes, 0 is to disable, 1 is to enable.
Ah OK!
Just to clarify, so setting this bit to 0 will disable the mask, which means it will allow the interrupt to happen. Setting this bit to 1 will enable the mask and hence mask the interrupt!
