Spi接口如何设置读取数据时miso为低电平
我在SPI0接了一个TPM芯片:slb9672
下面是设备树:
spi@3210000{
			status = "okay";
			spi@0 {
				status = "disabled";
			slb9670: slb9670@0{
				compatible = "infineon,slb9670";
				reg = <0>;
				spi-max-frequency = <10000000>;
				status = "okay";
				controller-data {
					nvidia,enable-hw-based-cs;
					nvidia,rx-clk-tap-delay = <0x10>;
					nvidia,tx-clk-tap-delay = <0x0>;
pinmux配置如下:
在安装模块tpm_tis_spi.ko时用逻辑分析器抓取读取数据时SPI波形如下:
图中MOSI是高电平,而正常工作时应该是低电平,请问应该如何修改?
我使用的SDK是Jetson_Linux 36.3,定制载板
Hi qiaowei.
MOSI is output pin. Please try configuring the column Req. Initial State to Drive 1 if you want it high at idle.
我需要MOSI空闲时是低电平,我修改了pinmux为Drive 0
生成设备树之后重新烧录了QSPI
但是我用逻辑分析仪测试MOSI还是高电平
怎么看修改是否生效?我在TRM文档中QSPI PAD Control Registers里面没有找到相关的寄存器
Could you share the result of the following command on your board?
$ sudo busybox devmem 0x0243d040
How about your clock? Idle with low level?
May I know what’s the SPI mode you want to use?
It should be configured in your SPI application.
执行这条命令结果是0x00000400
我看文档中这个寄存器是SPI1的,我使用的是SPI0
下面是读取其他寄存器的值:
是的,时钟空闲时是低电平,时钟信号是正确的
SPI应用程序是使用的Jetson Linux中的驱动:tpm_tis_core.ko和tpm_tis_spi.ko
SPI0 from Module is exact the SPI1 from SoC so that 0x0243d040 should be the correct register for your 89, SPI0_MOSI showing in pinmux spreadsheet.
0x400 means it is configured for SPI usage with none pull.
Could you try configure 0x404 for it to check?
$ sudo busybox devmem 0x0243d040 w 0x404
Please let me know which SPI mode would you like to use.
and what do you configure the SPI mode in your application?
谢谢,不需要了,我在论坛上找到答案了
