I’m trying to test spi on the Jetson TX2 and I’m facing a strange issue.
I’m using the nvidia jetson tx2 developer kit and I#M using the SPI interface which is connected to connector J21 (pin 19, 21, 23, 24).
I have followed the guide on following link to enable spi.
https://elinux.org/Jetson/TX2_SPI
Here a code snippet form my device tree:
spi@0 {
compatible = "spidev";
reg = <0x0>;
spi-max-frequency = <0x1312D00>;
spi-lsbyte-first = <0x0>;
nvidia,enable-hw-based-cs;
nvidia,cs-setup-clk-count = <0x1e>;
nvidia,cs-hold-clk-count = <0x1e>;
nvidia,rx-clk-tap-delay = <0x1f>;
nvidia,tx-clk-tap-delay = <0x0>;
For the first test I havn’t connected anything to the spi interface.
I wrote a small application which sends a read command first and then reads in some data.
Because of the reason i haven’t connected anything to the spi interface (and there is a pulldown on the MISO pin) I am expecting to read 0, but it seems that I’m getting some random numbers (0xe541 0xbacb 0xbaa5 …).
I would be very grateful anybody could help me with my problem.
This is the application i used for testing spi.
#include <stdint.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <getopt.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/types.h>
#include <linux/spi/spidev.h>
#include <string.h>
#include <errno.h>
int main(int argc, char **argv)
uint16_t data = 0;
uint16_t readCommand = 0x2;
struct spi_ioc_transfer mesg[2] = { {0}, };
char *device = "/dev/spidev3.0";
int ret;
int fd;
// Read command
mesg[0].tx_buf = (uint64_t)&readCommand;
mesg[0].rx_buf = (uint64_t)NULL;
mesg[0].len = 2;
mesg[0].delay_usecs = 0;
mesg[0].speed_hz = 100000;
mesg[0].bits_per_word = 16;
// Dummy
mesg[1].tx_buf = (uint64_t)NULL;
mesg[1].rx_buf = (uint64_t)&data;
mesg[1].len = 2;
mesg[1].delay_usecs = 0;
mesg[1].speed_hz = 100000;
mesg[1].bits_per_word = 16;
/* open device */
fd = open(device, O_RDWR);
if (fd < 0) {
printf("Could not open file %s (%s)\n", device, strerror(errno));
return -1;
/* send */
ret = ioctl(fd, SPI_IOC_MESSAGE(2), mesg);
if (ret < 0) {
printf("Could not read from file %s (%s)\n", device, strerror(errno));
return -1;
/* close device */
ret = close(fd);
if (ret < 0) {
printf("Could not close file %s (%s)\n", device, strerror(errno));
return -1;
printf("Read reg: %x \n", data);
return 0;
