SPI slave implementation in Jetson Nano Dev kit
I’m trying to implement Jetson Nano as SPI slave device.
I need to configure SPI Port0 as slave in Jetson Nano.
My SPI Host (Master) works with CLK speed = 1.5MHz, Data size = 16bits, CLK_POL = 0, CLK_PHA = 0, DataFormat = MSB first.
Below were the changes I made in “tegra210-p3448-0000-p3449-0000-b00.dts” dts file:
    spi@7000d400 {
            compatible = "nvidia,tegra210-spi-slave";
            status = "okay";
    spi@0   {
            status ="okay";
            spi-max-frequency = <1500000>;
    spi@1   {
            status = "okay";
I builded and flashed the code into Jetson Nano. But still it looks like Jetson Nano working as SPI Master.
Please let me know do I need to update any other parameters to configure the SPI slave in Jetson Nano?
I tried to check spi driver is enabled or not by using the below command
~$ dmesg | grep -i spi
[ 0.441260] iommu: Adding device 7000d400.spi to group 7
[ 0.441526] iommu: Adding device 7000d600.spi to group 8
@ShaneCCC
@WayneWWW
I’m looking forward to hearing from you.
Thanks and Regards
Mohan
Hi mohan.c,
You could refer to the following thread to configure SPI as slave.
SPI0 interface configured as a slave in Jetson Xavier NX - #10 by borjabasket14
Hi Kevin,
I’m using NVIDIA L4T 32.6.1 Jetpack version.
Could you help to update to latest R32.7.3 and verify?
Hi Kevin,
I tried flashing Jetson Nano Dev Kit with R32.7.3 package.
I got below errors after flashing and display is blank:
Failed to Start Docker Application Container Engine.
device-mapper: table: 253:0: thin-pool: unknown target type
device-mapper: ioctl: error adding target to table
