hi, NVIDIA. we use tx2 platform in our products.
we need to trans data by spi, and get err while transfer data int loop test.
errors behind:
[ 4636.333218] spi-tegra114 3240000.spi: CpuXfer ERROR bit set 0xc00004
[ 4636.341169] spi-tegra114 3240000.spi: CpuXfer 0x40601827:0x00000000
[ 4636.348859] spi-tegra114 3240000.spi: Error in Transfer
[ 4636.348887] spi-tegra114 3240000.spi: SPI_ERR: CMD_0: 0x40601827, FIFO_STS: 0x00c00004
[ 4636.348896] spi-tegra114 3240000.spi: SPI_ERR: DMA_CTL: 0x00000000, TRANS_STS: 0x40ff0005
[ 4636.375067] spi_master spi3: failed to transfer one message from queue
It seems result in spi configuration. If config spi trans in multi-bytes mode, and config the speed to 1Mbps, dmesg report err upon.
test tool by spidev_test:
#include <stdint.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <getopt.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/types.h>
#include <linux/spi/spidev.h>
#define SPI_MSG_NUM 2
#define ARRAY_SIZE(a) (sizeof(a) / sizeof((a)[0]))
static void pabort(const char *s)
perror(s);
abort();
static const char *device = "/dev/spidev3.0";
static uint32_t mode;
static uint8_t bits = 8;
static uint32_t speed = 1000000;
static uint16_t delay;
static int verbose;
uint8_t default_tx[] = {
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0x40, 0x00, 0x00, 0x00, 0x00, 0x95,
0xF0, 0x0D,
uint8_t default_rx[ARRAY_SIZE(default_tx)] = {0, };
char *input_tx;
static void hex_dump(const void *src, size_t length, size_t line_size, char *prefix)
int i = 0;
const unsigned char *address = src;
const unsigned char *line = address;
unsigned char c;
printf("%s | ", prefix);
while (length-- > 0) {
printf("%02X ", *address++);
if (!(++i % line_size) || (length == 0 && i % line_size)) {
if (length == 0) {
while (i++ % line_size)
printf("__ ");
printf(" | "); /* right close */
while (line < address) {
c = *line++;
printf("%c", (c < 33 || c == 255) ? 0x2E : c);
printf("\n");
if (length > 0)
* Unescape - process hexadecimal escape character
* converts shell input "\x23" -> 0x23
static int unescape(char *_dst, char *_src, size_t len)
int ret = 0;
char *src = _src;
char *dst = _dst;
unsigned int ch;
while (*src) {
if (*src == '\\' && *(src+1) == 'x') {
sscanf(src + 2, "%2x", &ch);
src += 4;
*dst++ = (unsigned char)ch;
} else {
*dst++ = *src++;
ret++;
return ret;
static void transfer(int fd, uint8_t const *tx, uint8_t const *rx, size_t len)
int ret;
#if 0
struct spi_ioc_transfer tr = {
.tx_buf = (unsigned long)tx,
.rx_buf = (unsigned long)rx,
.len = len,
.delay_usecs = delay,
.speed_hz = speed,
.bits_per_word = bits,
if (mode & SPI_TX_QUAD)
tr.tx_nbits = 4;
else if (mode & SPI_TX_DUAL)
tr.tx_nbits = 2;
if (mode & SPI_RX_QUAD)
tr.rx_nbits = 4;
else if (mode & SPI_RX_DUAL)
tr.rx_nbits = 2;
if (!(mode & SPI_LOOP)) {
if (mode & (SPI_TX_QUAD | SPI_TX_DUAL))
tr.rx_buf = 0;
else if (mode & (SPI_RX_QUAD | SPI_RX_DUAL))
tr.tx_buf = 0;
ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);
if (ret < 1)
pabort("can't send spi message");
#else
struct spi_ioc_transfer multi_tr[SPI_MSG_NUM] = {0};
int i = 0;
for (i = 0; i < SPI_MSG_NUM; i++)
multi_tr[i].tx_buf = (unsigned long)tx;
multi_tr[i].rx_buf = (unsigned long)rx;
multi_tr[i].len = len;
multi_tr[i].delay_usecs = delay;
multi_tr[i].speed_hz = speed;
multi_tr[i].bits_per_word = bits;
printf("speed %d\n", speed);
multi_tr[i].tx_nbits = 4;
multi_tr[i].tx_nbits = 2;
multi_tr[i].rx_nbits = 4;
multi_tr[i].rx_nbits = 2;
multi_tr[i].rx_buf = 0;
multi_tr[i].tx_buf = 0;
ret = ioctl(fd, SPI_IOC_MESSAGE(SPI_MSG_NUM), &multi_tr);
if (ret < 1)
#endif
if (verbose)
hex_dump(tx, len, 32, "TX");
hex_dump(rx, len, 32, "RX");
static void print_usage(const char *prog)
printf("Usage: %s [-DsbdlHOLC3]\n", prog);
puts(" -D --device device to use (default /dev/spidev1.1)\n"
" -s --speed max speed (Hz)\n"
" -d --delay delay (usec)\n"
" -b --bpw bits per word \n"
" -l --loop loopback\n"
" -H --cpha clock phase\n"
" -O --cpol clock polarity\n"
" -L --lsb least significant bit first\n"
" -C --cs-high chip select active high\n"
" -3 --3wire SI/SO signals shared\n"
" -v --verbose Verbose (show tx buffer)\n"
" -p Send data (e.g. \"1234\\xde\\xad\")\n"
" -N --no-cs no chip select\n"
" -R --ready slave pulls low to pause\n"
" -2 --dual dual transfer\n"
" -4 --quad quad transfer\n");
exit(1);
static void parse_opts(int argc, char *argv[])
while (1) {
static const struct option lopts[] = {
{ "device", 1, 0, 'D' },
{ "speed", 1, 0, 's' },
{ "delay", 1, 0, 'd' },
{ "bpw", 1, 0, 'b' },
{ "loop", 0, 0, 'l' },
{ "cpha", 0, 0, 'H' },
{ "cpol", 0, 0, 'O' },
{ "lsb", 0, 0, 'L' },
{ "cs-high", 0, 0, 'C' },
{ "3wire", 0, 0, '3' },
{ "no-cs", 0, 0, 'N' },
{ "ready", 0, 0, 'R' },
{ "dual", 0, 0, '2' },
{ "verbose", 0, 0, 'v' },
{ "quad", 0, 0, '4' },
{ NULL, 0, 0, 0 },
int c;
c = getopt_long(argc, argv, "D:s:d:b:lHOLC3NR24p:v", lopts, NULL);
if (c == -1)
break;
switch (c) {
case 'D':
device = optarg;
break;
case 's':
speed = atoi(optarg);
break;
case 'd':
delay = atoi(optarg);
break;
case 'b':
bits = atoi(optarg);
break;
case 'l':
mode |= SPI_LOOP;
break;
case 'H':
mode |= SPI_CPHA;
break;
case 'O':
mode |= SPI_CPOL;
break;
case 'L':
mode |= SPI_LSB_FIRST;
break;
case 'C':
mode |= SPI_CS_HIGH;
break;
case '3':
mode |= SPI_3WIRE;
break;
case 'N':
mode |= SPI_NO_CS;
break;
case 'v':
verbose = 1;
break;
case 'R':
mode |= SPI_READY;
break;
case 'p':
input_tx = optarg;
break;
case '2':
mode |= SPI_TX_DUAL;
break;
case '4':
mode |= SPI_TX_QUAD;
break;
default:
print_usage(argv[0]);
break;
if (mode & SPI_LOOP) {
mode |= SPI_RX_DUAL;
mode |= SPI_RX_QUAD;
int main(int argc, char *argv[])
int ret = 0;
int fd;
uint8_t *tx;
uint8_t *rx;
int size;
parse_opts(argc, argv);
fd = open(device, O_RDWR);
if (fd < 0)
pabort("can't open device");
* spi mode
ret = ioctl(fd, SPI_IOC_WR_MODE32, &mode);
if (ret == -1)
pabort("can't set spi mode");
ret = ioctl(fd, SPI_IOC_RD_MODE32, &mode);
if (ret == -1)
pabort("can't get spi mode");
* bits per word
ret = ioctl(fd, SPI_IOC_WR_BITS_PER_WORD, &bits);
if (ret == -1)
pabort("can't set bits per word");
ret = ioctl(fd, SPI_IOC_RD_BITS_PER_WORD, &bits);
if (ret == -1)
pabort("can't get bits per word");
* max speed hz
ret = ioctl(fd, SPI_IOC_WR_MAX_SPEED_HZ, &speed);
if (ret == -1)
pabort("can't set max speed hz");
ret = ioctl(fd, SPI_IOC_RD_MAX_SPEED_HZ, &speed);
if (ret == -1)
pabort("can't get max speed hz");
printf("spi mode: 0x%x\n", mode);
printf("bits per word: %d\n", bits);
printf("max speed: %d Hz (%d KHz)\n", speed, speed/1000);
if (input_tx) {
size = strlen(input_tx+1);
tx = malloc(size);
rx = malloc(size);
memset(tx, 0x5e, sizeof(tx));
size = unescape((char *)tx, input_tx, size);
transfer(fd, tx, rx, size);
free(rx);
free(tx);
} else {
transfer(fd, default_tx, default_rx, sizeof(default_tx));
close(fd);
return ret;
Anyone has same error mesg,beg your help.
looking foraward replay. thanks!
