SPI Troubles
I am trying to use the GPIO header to power LEDs. I am following a tutorial from AdaFruit (Initial Setup | CircuitPython Libraries on Linux and the NVIDIA Jetson Nano | Adafruit Learning System).
I run: sudo /opt/nvidia/jetson-io/jetson-io.py
I Select Configure 40-pin expansion header at the bottom.
I Select spi1 (19, 21, 23, 24, 26) and then select Back
I Finally select Save and reboot to reconfigure pins . This will create a config file and reboot the Jetson Nano.
I run: ls /dev/i2c* /dev/spi*
I get:
nano@nano:~$ ls /dev/i2c* /dev/spi*
ls: cannot access ‘/dev/spi*’: No such file or directory
/dev/i2c-0 /dev/i2c-2 /dev/i2c-4 /dev/i2c-6
/dev/i2c-1 /dev/i2c-3 /dev/i2c-5
I am expecting more files such as:
/dev/spidev0.0, /dev/spidev0.1, /dev/spidev1.0 and /dev/spidev1.1
I am not sure what I am doing wrong - I have tried doing the process several times. I feel like this might be a permission thing? I have tried to modify permissions of the dev folder (chmod 777 /dev/) but it is not working.
When it reboots, it hangs and says a process is still running and waits for 89 seconds and then reboots.
Any help would be greatly appreciated.
Run below command after reboot
sudo modprobe spidev
